Re: Idle speed high after throttle body cleaning 3.4
"Lhead" wrote:[color=blue]
>’95 T100 3.4 automatic.
>Yesterday I pulled the intake snorkel from the throttle body and
>cleaned the gunk out that was on and around the throttle butterfly.[/color]
Of[color=blue]
>course, I did it with the engine off. Quite a bit of crud too.
>Upon putting everything back together and starting the engine, my[/color]
idle[color=blue]
>speed is now probably 1200 RPM according to the tach. The manual
>specifies 650-750 in park with the engine at operating temp.
>I’ve
>disconnected the battery in an effort to "reset" the engine[/color]
computer[color=blue]
>since I thought that with the different airflow parameters after the
>cleaning that the computer would have to relearn data from the idle
>air
>control valve.
>So anyway, can I reasonably expect the idle speed to return to normal
>after a few days/miles of operation?
>Thanks for any knowledge you can send my way.[/color]
You might have damaged the Idle Control Valve that the ECM uses to
controll idle speed. It is electrically controlled.
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/Toyota-Idle-speed-high-throttle-body-cleaning-ftopict127737.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=622854[/url]
