Grinding Noise when starting - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-10-2005, 02:36 PM   #1 (permalink)
MEHM
Guest
Posts: n/a
View MEHM's Photo Gallery
I am wondering if anyone can help me figure out what is wrong with my 1988
Toyota truck. Just recently when I turn on the truck, it makes a short
grinding (or grating noise). The noise only lasts for a few seconds, and
then the truck runs fine. Although it is a '88 truck, it only has 26,000
miles. Any suggestions would be appreciated. Thank you!
Old 07-10-2005, 03:06 PM   #2 (permalink)
bbtaco
Guest
Posts: n/a
View bbtaco's Photo Gallery
Re: Grinding Noise when starting
"MEHM" <cox@alaska.net> wrote in message
news:8ffaccc7f51611dbf1c828be544b143d@localhost.talkaboutautos.com...[color=blue]
>[/color]
You may have some worn gear teeth on the starter or flywheel. Does it always
do it or just sometimes?
Old 07-10-2005, 03:20 PM   #3 (permalink)
MEHM
Guest
Posts: n/a
Thank you for taking the time to write. The grinding just starting, but it
is now happening everytime I start it. This is sounding very expensive!
Old 07-10-2005, 04:00 PM   #4 (permalink)
bbtaco
Guest
Posts: n/a
news:62791c142633da8b327437e9cb6d489c@localhost.talkaboutautos.com...[color=blue]
> it
>[/color]
I would have the battery and charging system checked. I know Autozone and
Advance Auto stores will check it for free. Check for loose or corroded
cables. Make sure the starter is not missing any bolts (You can have someome
crank the truck while you are watching the starter to see of there is any
movement). Of course while not standing directly in front, just in case. :)
Has the starter ever been replaced? If it's the starter, I would have
whoever replaces it visually check all of the teeth on the flywheel while
they are at it.
Old 07-10-2005, 05:48 PM   #5 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
MEHM wrote:[color=blue]
> 1988 Toyota truck. Just recently when I turn on the truck, it makes
> a short grinding (or grating noise). The noise only lasts for a few
> seconds, and then the truck runs fine. Although it is a '88 truck,
> it only has 26,000 miles. Any suggestions would be appreciated.
> Thank you![/color]
You could have a loose starter which would let the starter nose and/or gear
grind on flywheel or the starter drive gear may be sticking.
Check for loose starter and if that's not it I'd remove starter and bench
test. If it is a sticking drive gear it will damage flywheel to the point it
will have to be replaced. If you remove starter check flywheel teeth to
ensure they are ok and flywheel isn't loose or gear ring isn't loose on
flywheel. Flywheel teeth can have a little damage on the leading edge before
they have to be replaced.
HTH, davidj92
Old 07-10-2005, 08:26 PM   #6 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
With that few miles on it - I bet the starter is all rusty inside or the
grease is hardened and the gear that engages the flysheel isn't able to run
free/release.. I'd pull the starter and thoroughly clean it (or swap it for
a rebuilt one - I prefer the original over a rebuilt one ) before it eats
the teeth off the flywheel. Here's link to instructions on how to remove
the starter:
[url]http://www.4x4wire.com/toyota/maintenance/starter/[/url]
"davidj92" <davidj92@sigecom.net> wrote in message
news:q-qdnaS_7boJCkzfRVn-qA@sigecom.net...[color=blue]
> MEHM wrote:[color=green]
>> Thank you![/color]
> gear grind on flywheel or the starter drive gear may be sticking.
> it will have to be replaced. If you remove starter check flywheel teeth to
> before they have to be replaced.
> HTH, davidj92
>[/color]
Old 07-10-2005, 09:33 PM   #7 (permalink)
N/A bites
Tercel GTS's Avatar
[QUOTE=davidj92]MEHM wrote:[color=blue]
> Thank you![/color]
HTH, davidj92[/QUOTE]
^agreed
Prolly loose, my 81 used to loosen up from time to time.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 07-10-2005, 10:07 PM   #8 (permalink)
Malcom Gillette
Guest
Posts: n/a
View Malcom Gillette's Photo Gallery
I can tell you that the longer you wait, the more expensive it will become,
Malcom
> Thank you for taking the time to write. The grinding just starting, but[/color]
it[color=blue]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
