Re: Battery/Brake Light won't go out...
If the brake and charge lights come on during revving of the engine
then it's a sign that the carbon alternator brushes require replacing
as this is the mileage for them to wear out. In alternators the brushes
wear out on average every 140-170 000 miles where on the dashboard the
brake & charge light both come on at the same time. About half of the
auto electric shops in your local yellow pages sell carbon alternator
brushes and copper solenoid starter contacts for about $5/pair.Another
way to verify that the alternator is not charging is while the engine
is running bring a metal screwdriver or any metal object near the
alternator and if the alternator is working properly then it should act
like a magnet and grab the screwdriver.
For carbon brushes R&R:
[url]http://www.4x4wire.com/toyota/maintenance/alternator_brushes/[/url]
[url]http://www.toyotaoffroad.net/afertig/88/alternatorbrushes.htm[/url]
[url]http://perso.wanadoo.fr/adherence.4x4/alternateur_kzj.htm[/url]
[url]http://www.automotiveforums.com/vbulletin/showthread.php?t=166525[/url]
[url]http://www.toyotanation.com/forum/showthread.php?threadid=27270&forumid=10[/url]
[url]http://www.pirate4x4.com/forum/showthread.php?s=&threadid=26734&highlight=alternator+brush+holder[/url]
[url]http://www.bitwalla.com/cruisers/articles/alternator.html[/url]
[url]http://www.barneymc.com/toy_root/techtalk/electric/altrnatr.htm[/url]
For decoding the dashboard lights:
[url]http://www.powerbase-auto.co.uk/alternator_faults.htm[/url]
[url]http://members.1stconnect.com/anozira/SiteTops/energy/Alternator/alternator..htm[/url]
Here are part #'s for Toyota alternator carbon brushes and copper
solenoid starter contacts which are used in about 95% of all Toyota
vehicles.
Toyota alternator Brushes with holder:
Toyota # 27370-35060=$29 CDN
Honda # 31105-PZ1-003
Metro # 39-82003 ([url]www.metroautoinc.com[/url] ,Pomona,California)
Unknown brand name # F4019-53035
Alternator brush only (qty:1 brush unless otherwise stated):
AC Delco # E724
AC Delco # E731 (side wire and concave tip)
Ace Electric # DA-61 (brush only),S-5367 (brush holder)
Beck Arnley # 178-1669 (side wire and concave tip)
Beck Arnley # 178-1376
Borg Warner # X580 (side wire and concave tip)
Canadian Tire # 19-2050-6=$4.49/pair
Daihatsu # 27370-87302-000
Daihatsu # 27371-63020-000
Daihatsu # 27371-87501-000
Daihatsu # 27371-70300-000
Echlin # E601=$8.16 CDN/pair (UAP/NAPA)
Echlin # ECHE601
Echlin # EC480
Echlin # ECHE480
GP Sorensen # 255047 (side wire and concave tip)
GM # 94123056
GM # 96054118
Honda # 31144-PD1-004=$9.72
Honda # 31144-PD1-0040
Honda # 31144-PD1-0030
Honda # 31150-PR7-A01
Honda # 31150-PTO-003
Hino Industries # 021660-0390
Hino Industries # 021660-0510
Isuzu # 8-94123-056-0
Isuzu # 8-97032-308-0
Isuzu # 8-97032-310-0
Mazda # 021660-0390
Mazda # 021660-0510
Mazda # KL47-18-W75
Metro # 38-82001(side wire concave tip) ([url]www.metroautoinc.com[/url]
,Pomona,California)
Mileage Plus # E601SB
Mitsubishi # MD604474
Mitsubishi # 21660-0510
Niehoff # WA571 (side wire and concave tip)
NipponDenso # 021660-0390
NipponDenso # 021660-0510
Standard # JX-116 (side wire and concave tip)
Subaru # 021660-0390
Subaru # 021660-0510
Suzuki # 31631-82610
Suzuki # 31656-82611
Suzuki # 021660-0510
Toyota # 27370-42010
Toyota # 27370-75060
Toyota # 27371-63020=$5.80 (up to 9105) (side wire and concave tip)
Toyota # 27371-70300=$5.20 (9105-9511)
Toyota # 27371-76004-71
UAP/NAPA # MPEE601SB
Victory Lap # FAX57=$4.49 CDN/pair (Canadian Tire)
Wilson's Electric # 26-29-7534 (side wire and concave tip)=$2.20 each
CDN (Diesel Auto Electric)(Parts for Trucks,box of 10 for $3.40 CDN)
Specifications:
Length=15 mm
Width=7 mm
Thickness=5 mm
Lead length=49 mm
These Honda alternators are the same except the pulley must be swapped:
1986-89 Honda Accord (Carb),the EFI can be used but the voltage reg
must be swapped
1990-93 Acura Integra
15 Toyota (NipponDenso now called Denso) starter repair sites:
[url]http://www.off-road.com/4x4web/toyota/tech/starter/[/url] -
[url]http://www.4crawler.com/4x4/CheapTricks/Starter.shtml[/url]
[url]http://char.tuiasi.ro/vw/reality/rogerb/4x4/CheapTricks/Starter.html[/url]
[url]http://yotarepair.com/startercontacts.html[/url]
[url]http://www.toyotaoffroad.net/afertig/88/starterrepair.htm[/url]
[url]http://www.4x4wire.com/toyota/maintenance/starter/[/url]
[url]http://www.yotatech.com/~corey/tech/haveblue_starter/haveblue.htm[/url]
[url]http://www.sleeoffroad.com/technical/tz_starter_rebuild.htm[/url]
[url]http://www.startercontacts.com/install.htm[/url]
[url]http://www.startercontacts.com/images/OSGR%20Exploded%20view.jpg[/url]
[url]http://www.colorado4x4.net/tech/starter_contacts/starter_contacts.html[/url]
[url]http://www.barneymc.com/toy_root/techneek/starter.htm[/url]
[url]http://perso.wanadoo.fr/adherence.4x4/start_bj.htm[/url]
[url]http://www.automotiveforums.com/vbulletin/showthread.php?t=166530[/url]
[url]http://www.toyotanation.com/forum/showthread.php?threadid=27312&forumid=10[/url]
[url]http://www.toyotanation.com/showthread.php?threadid=27312&forumid=10[/url]
Starter contact kits (8mm ID hole):
Ace Electric # S-5263 (only two contacts)
Ace Electric # S-5264 (only two contacts)
Metro # 66-82104 (only two contacts) ([url]www.metroautoinc.com[/url]
,Pomona,California)
Toyota # 28226-72010/80 (battery side)(also1KZTE-2LT-1KZT)
Toyota # 28226-72080 (8808-9108)
Toyota # 28226-16130 (9108-9308)
Toyota # 28226-55050 (9308-9511)
Toyota # 28226-70040 (9308-9511)
Toyota # 28226-72040 (motor side if needed)
Toyota # 28226-72010 (8808-9511)
Toyota # 28226-74070 (9108-9511)
For others besides 22R series:
Toyota # 28226-54220 (motor side) (2LTE, 3L..LN13# IKZTE, 2L#,
KZN130,LN108,112,85..4FC)
Toyota # 28226-54250 (Diesel Surf 2.4TD, contains a new end cover and
gasket)
Toyota # 28226-54320 (battery side) (2LTE, 3L..LN13# IKZTE, 2L#,
KZN130, LN108,112,85..4FC,3B-1HZ-BJ73-HZJ7#-1KZT-KZJ70)
Toyota # 28226-17030 (battery side) (1H#-HDJ80-HZJ80)
Toyota # 28226-56250 (battery side) (3B-1HZ-1PZ-PZJ7#)
Starter contacts only (8mm ID hole):
Ace Electric # S-5231
Ace Electric # S-5293 (crescent moon shape)
Ace Electric # S-5295 (crescent moon shape)
Metro # 66-82106 ([url]www.metroautoinc.com[/url] ,Pomona,California)
Tons more at:
[url]http://www.metroautoinc.com/PDF%20File/66-Denso%20Solenoid%20Contact.pdf[/url]
Wilson's Electric # 45-29-652
Starter brushes:
AC Delco # D762
GP Sorensen # 255048
Standard # JX-117
Whether your starter uses two rectangular types or one rectangular and
one crescent you can substitute with two squares or one square and one
crescent so any of the above part #'s for those kits will be the right
ones,or about half of the auto electric shops in your local yellow
pages would sell aftermarket contacts for only $5 each or the pair.
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise
control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome
bumper with 245 000 KM
Mess wrote:[color=blue]
> After driving 2300 miles my battery and brake lights came on. I changed the
> battery out, light is still on. Is it the altenator, some thing else...???[/color]
