gas leak 89 6cly 4x4 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-11-2005, 11:15 AM   #1 (permalink)
Keyser Soze
Guest
Posts: n/a
View Keyser Soze's Photo Gallery
We have an 89 sr5 that's leaking badly from the top of the fuel tank. It
appears to be the metal line coming out of the tank. Is it possible to pull
this in place or do we have to drop the tank. Is in a blind spot. Thanks.
Old 07-11-2005, 04:56 PM   #2 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
Re: gas leak 89 6cly 4x4
Keyser Soze wrote:[color=blue]
> It appears to be the metal line coming out of the tank. Is it
> possible to pull this in place or do we have to drop the tank. Is in
> a blind spot. Thanks.[/color]
Many times it's easier to remove the bed on a PU than to drop the tank. Ones
I've done this way I just uncoupled filler tube, any clips on bed frame,
light wires to rear and remove bed bolts (usually 4 - 6 bolts and easy to
get to. Two good men should be able to lift a bed that small. Another
benefit is not having to dump fuel from tank and mess with a tank with fuel
in it. If you find it's the tank that's leaking it's easier to R&R with the
bed off.
HTH, davidj92
Old 07-12-2005, 09:16 AM   #3 (permalink)
Keyser Soze
Guest
Posts: n/a
"davidj92" <davidj92@sigecom.net> wrote in message
news:eKmdndbv3b2XQE_fRVn-1g@sigecom.net...[color=blue]
> Keyser Soze wrote:[color=green]
> Ones I've done this way I just uncoupled filler tube, any clips on bed
> frame, light wires to rear and remove bed bolts (usually 4 - 6 bolts and
> easy to get to. Two good men should be able to lift a bed that small.
> Another benefit is not having to dump fuel from tank and mess with a tank
> with fuel in it. If you find it's the tank that's leaking it's easier to
> R&R with the bed off.
> HTH, davidj92[/color]
Thanks for the advice. I already have dropped the tank. A PIA but got it
done.
Just for anyone else who may Google the effort... The truck is an 89 V6 Xcab
4X4 w 250,000 miles.
Six 12mm bolts hold the skid plate protective covering. Once removed, there
are six more 12mm bolts holding the tank up. I drained the tank and then
removed the bolts.
I had to use vice grips to remove the three screws holding the filler tube.
After some juggling the tank was lowered and I could get to the hoses and
electrical connections. Fortunately, Toyota engineered enough slack to lower
the tank!
A 19mm and 14mm wrench loosened the gasoline supply hookup.
Now to the pump....
BB code is Off
Smilies are Off
[IMG] code is Off
