Re: transmission dropping?
On 25 Jul 2005 19:35:37 -0400, Mikang <UseLinkToEmail@AutoForumz.com>
wrote:
[color=blue]
>Thanks for the info. My 2003 truck was doing this from the first time
>I drove it off the dealer’s lot and when questioning the dealer’s shop
>supervisor, the only answer that I received was that what was
>happening was normal for my truck. It sure doesn’t feel normal.[/color]
I've driven cars where the driveshaft spline joint did that little
pop and jerk, and you are right, it can be annoying.
You just have to get your subconscious trained to not panic on known
and explained noises - but not to ignore new ones that could be a
warning of real trouble.
Or buy yourself a grease gun, a creeper, a set of ramps and a set of
jackstands. When you notice the joint starting to pop again, crawl
underneath your truck and give it a shot of grease. Takes only
minutes, and the problem is solved for another few months.
But there's one HUGE problem with this plan of action that you have
to consciously avoid - it all starts with little things like doing
your own chassis lube work. Then oil changes and air filters, then
you start doing your own body repairs and paint touch-ups...
And before you know it, your rollaway tool chest and all the toys
in it would make a pro mechanic jealous, and you're shopping around
for a two-post lift and a building contractor to raise your garage
roof up two feet for more clearance...
<TV Commercial>
"How do I do it? I'm in debt up to my eyeballs. Somebody help me..."
;-P
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
