Re: 2001 Toyota 4 runner 6cyl VSC lights on ?
I also had this problem. The first time I had it checked the mechanic could
not find anything wrong. The code indicated a vacuum leak. The mechanic
checked everything and nothing found. He reset everything and took out for
a test drive. The lights did not come back on. After about 2 months the
problem reappeared. It turned out to be a sensor around the gas tank that
went bad. Replaced it and the problem is gone.
"BR" <bkrjeh@twcny.rr.com> wrote in message
news:98ZAe.26327$e%5.4008@twister.nyroc.rr.com...[color=blue]
> While driving my truck today the "VSC OFF" and the "VSC TRAC" and "CHECK
> ENGINE " Light came on, any clues as to what the cause would be ?
>[/color]
