brake light - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-15-2005, 02:33 PM   #1 (permalink)
SilverCobra
Guest
Posts: n/a
View SilverCobra's Photo Gallery
brake light
My rear right brake light stays on constantly when I have my lights on.
When I put my brakes on my left light goes as bright as the right, but
then dims like it is supposed to when I let off the brake. The right one
stays the same brightness though. It is like I have my emergency brake on,
but I don't, and that is the only side that lights up like that. If anyone
else has encountered this problem please tell me what I can do or what is
wrong. Thx
Old 07-16-2005, 12:40 PM   #2 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
Re: brake light
SilverCobra wrote:[color=blue]
> on. When I put my brakes on my left light goes as bright as the
> right, but then dims like it is supposed to when I let off the brake.
> The right one stays the same brightness though. It is like I have my
> emergency brake on, but I don't, and that is the only side that
> lights up like that. If anyone else has encountered this problem
> please tell me what I can do or what is wrong. Thx[/color]
Have you recently replaced bulb? If so, the bulb could be in backwards or
180deg off. The next logical think of is a short in wiring.
HTH, davidj92
Old 07-19-2005, 02:59 AM   #3 (permalink)
dissembler
Guest
Posts: n/a
View dissembler's Photo Gallery
Re: brake light
are you wired for a trailer? sometimes the converter box between where you
tapped into the taillights and the trailer plug goes bad. mine did.
Old 08-03-2005, 02:10 PM   #4 (permalink)
SilverCobra
Guest
Posts: n/a
Re: brake light
I almost hate to admit that it was this simple but it was just in wrong. I
took it out and turned it around 180 degrees and now it works fine. Thanks
Old 08-03-2005, 06:20 PM   #5 (permalink)
davidj92
Guest
Posts: n/a
Re: brake light
> wrong. I took it out and turned it around 180 degrees and now it
> works fine. Thanks[/color]
Don't feel bad, even the most experienced will do this sometimes. :-)
davidj92
BB code is Off
Smilies are Off
[IMG] code is Off
