Re: What is it and why is it leaking oil?
Assuming it's the V6 you have and you know it's not the oil filter
leaking. It could be the oil cooler. The dipwad could have tried to
remove it thinking it was the oil filter and screwed it up.
On Fri, 19 Aug 2005 21:23:22 -0700, Larry Talkington wrote:
[color=blue]
> I have a '95 4x4 that has suddenly started leaking oil (266K mi),
> started right after a cheapie oil change On inspection the oil seems to
> be coming from a round assembly just above the oil pan on the drivers
> side. Any one know what the assembly is and/or why it has started
> leaking? Other than the obvious,( the 16 yo minimum wage working in the
> pit was screwing around with it.) TIA[/color]
