Parking Brake warning light problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 08-21-2005, 06:05 PM   #1 (permalink)
DB
Guest
Posts: n/a
View DB's Photo Gallery
My parking brake warning light on the dash stays on but is very dim when the
parking brake is off. You don't notice it during the day, it's only bright
enough to see at night. The brake is all the way off and the switch is
working fine. It will get dimmer once in a while and then go off for a
while and then come back on again very dim. I'm guessing a bad ground is
the problem.
Is there a common problem area? Where do I start?
Old 08-21-2005, 10:45 PM   #2 (permalink)
Pop-N-Fresh
Guest
Posts: n/a
View Pop-N-Fresh's Photo Gallery
Re: Parking Brake warning light problem
DB wrote:[color=blue]
> the problem.
> Is there a common problem area? Where do I start?[/color]
hey bro your brake fluid is low... try topping it off and tell us if it
fixes it
Old 08-22-2005, 07:37 AM   #3 (permalink)
raveen.b@gmail.com
Guest
Posts: n/a
View raveen.b@gmail.com's Photo Gallery
yes, the brake-fluid might be low,
and check if there are any oil streaks on your tires, that are
indicative of the brake-fluid leak/loss, which might have caused this
as it was in my case, or else normal wear and tear.
Old 08-22-2005, 08:53 PM   #4 (permalink)
DB
Guest
Posts: n/a
Sorry, I should have mentioned the fluids were OK. Fluid is at full (at max
line), no leaks or problems with the brakes. Any other ideas? I guess it's
possible the cap and sensor on top of the fluid reservoir is faulty. Any
way to check it?
"Pop-N-Fresh" <linux.server@charter.net> wrote in message
news:1124678750.646727.15530@g43g2000cwa.googlegroups.com...[color=blue]
> DB wrote:[color=green]
>> the
>> bright
>> the problem.
> fixes it
>[/color]
Old 08-22-2005, 09:01 PM   #5 (permalink)
Pop-N-Fresh
Guest
Posts: n/a
thats a bit outta my league... might have a garage just check it
out.... might not be anything worth worrying over
BB code is Off
Smilies are Off
[IMG] code is Off
