Re: Coming to 4WD from AWD
On Wed, 24 Aug 2005 13:25:40 -0500, Nobody Special
<enar@stribmail.com> wrote:
[color=blue]
>"Doug Kanter" <ancientangler@hotmail.com> wrote in
>news:vR2Pe.5174$cg.1223@news02.roc.ny:[color=green]
>> You won't be using it on dry paved roads, and probably not
>> unpaved roads, either, unless they're muddy. The first time
>> you make tight turns with 4WD on a dry road, you'll hear &
>> feel some interesting things that'll remind you to shut it
>> off.[/color]
>Thanks. So not too much to "unlearn" from my Honda experiences,
>then? ;-)[/color]
With a part time 4WD system there is no differential between the
front and rear axles. Make a turn with the 4WD engaged on dry
pavement, and the driveshafts bind up until one of two things happens:
Either one wheel chooses to slip intermittently and relieve the torque
till you straighten out, or something in the driveline breaks.
If you have the system with manual hubs and a manual shifter, and
you expect some hairy driving may happen today, you can lock the hubs
on dry pavement. But don't shift the transfer case into 4WD till you
get into the slop and need it. This saves you from wading out in a
foot of mud to lock the hubs /after/ you get stuck.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
