Re: 91 Previa: Need advice on burning motor oil
This is getting funny here.
Toyota dealership is charging me for $50 to check for any oil leak.
I dropped by to a local shop, they asked me CLEAN UP/WASH the engine
before they check the leaks. I can not afford any blames from my lovely
wife, she might say what I do to the drive way.
To another shop, the mechanic told me, it could leak inside the engine
combustion, so it probably easier just get a re-build engine, $2000, for
this old $1500 mini-van. He is honest and told me don't do anything just
add in motor oils as frequent as possible, LEAVE it ALONE. It is true that
would cost me about $100 per year and would take 20 years to get even on
re-built engine.
On Fri, 26 Aug 2005 05:01:20 -0500, davidj92
wrote:
[color=blue]
> dbmethods wrote:[color=green]
>> Actually I think one of valves/gaskets in somewhere is leaking. I do
>> smell something when parking it inside the garage.[/color]
> I suggest you see your mechanic on getting any leaks fixed. They are
> expensive to maintain (you say 1 qt. @750 miles x $2.?? per qt. =$$$) and
> usually inexpensive to get fixed. If your mechanic hasn't addressed this
> issue and suggests motor honey and you don't have internal engine noises I
> would suggest finding another mechanic.
> The Sears DIEHARD[color=green]
>> battery still very strong for over 6 years, I do not have any problem
>> to start it up and no blue smoke yet.[/color]
> This would eliminate the valve guide seals which would be another
> easy/inexpensive fix so back to the leaks which I suspect is the major cause
> of your oil usage.
> I am in North East, winter is[color=green]
>> cold here. Should I still use 10w40 for winter season?
>>[/color]
> Since you have 135k miles I would probably switch to 10w30, possibly 5w30 in
> cold weather as the engine probably has enough clearances on bearings and
> etc to stand these viscosities.
> HTH, davidj92[/color]
