hubby charged battery wrong, now will not crank - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 08-25-2005, 07:37 PM   #1 (permalink)
nothappywithhusband
Guest
Posts: n/a
View nothappywithhusband's Photo Gallery
My husband left his lights on at work. When I went to go jump him off, he
put the - cable on the + side and vice versa. He lost all power to the
inside of his cab. The head lights will still come on, but that is it.
Daddy checked the starter and the alternator and they seem to be fine. My
dad is a mechanic and he is stumped. What else could have happeded, a
blown fuse or relay, a wire shorage....I need some ideas?
Old 08-25-2005, 08:32 PM   #2 (permalink)
Searcher1
Guest
Posts: n/a
View Searcher1's Photo Gallery
Re: hubby charged battery wrong, now will not crank
Main fise is most likely blown, Although, we could probably better help you
if you gave the information as to what make model and year vehicle you have.
Searcher1
Old 08-26-2005, 06:08 AM   #3 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
nothappywithhusband wrote:[color=blue]
> off, he put the - cable on the + side and vice versa. He lost all
> power to the inside of his cab. The head lights will still come on,
> but that is it. Daddy checked the starter and the alternator and they
> seem to be fine. My dad is a mechanic and he is stumped. What else
> could have happeded, a blown fuse or relay, a wire shorage....I need
> some ideas?[/color]
Sometimes when polarity is reversed while jump starting you can burn out a
section of the wiring harness, usually around the starter solonoid relay
and/or alternator. Since the headlights are direct wired outside of the
charging/ignition circuits they can still work while there is no power for
any other circuits. You need to check fuses as suggested in Searchers' post
and if no bad ones are found then start with voltage checks along wiring
harness(s).
davidj92
BB code is Off
Smilies are Off
[IMG] code is Off
