2001 Tacoma 3.4l Check Engine - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 08-28-2005, 10:50 AM   #1 (permalink)
Grif
Guest
Posts: n/a
View Grif's Photo Gallery
During the past year or 25k miles I've had problems with an engine
light with code p0420 which is cat efficiency low. I was told to
replace the secondary o2 sensor and clean the mass airflow sensor. I
replaced them both while I was doing it. That seemed to take care of
the problem until about a week ago when the same code fired. I always
check with the local dealer to see if there are others with similar
issues, but they're never much help. I am not against replacing the
dual cat system, but want some advise before I drop any more money at
this. Any help would be appreciated
Thanks
Grif
Old 08-31-2005, 08:21 PM   #2 (permalink)
johngdole@hotmail.com
Guest
Posts: n/a
View johngdole@hotmail.com's Photo Gallery
Re: 2001 Tacoma 3.4l Check Engine
The sensors ($$$) are the symptoms and not the cause.
You need to check the fuel delivery, ignition, and air/exhaust leaks.
Because if you don't solve the actual problem, it will continue to
damage your sensors and eventually the converters if not already.
Unless there is a recall or knowledge on a bad batch of converters or
sensors.
When did you last had a tune up?
BB code is Off
Smilies are Off
[IMG] code is Off
