1987 Toyota 4x4 Pickup 22RE - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 08-29-2005, 03:22 PM   #1 (permalink)
Calgunz
Guest
Posts: n/a
View Calgunz's Photo Gallery
The #2 and #3 cylinders are not firing and the
plugs are wet. Both went at the same time and not sure what was the
problem. Had a bit of valve tap before it happened. I have changed the
plug wires, and checked for spark. There is spark at all cylinders .
Everything moves freely. Compression with all plugs out is 155 - 165 in
all cylinders. Had a crowler cam installed 2K miles ago and this is first
problem since. anybody got any thoughts. I have replaced wires, cap and
rotor. Thanks for the help.
Old 08-29-2005, 05:45 PM   #2 (permalink)
Jarhead
Guest
Posts: n/a
View Jarhead's Photo Gallery
Re: 1987 Toyota 4x4 Pickup 22RE
"Calgunz" <jeff.quarles@cox.com> wrote in message
news:7275ca3f66559e8812adb9c681ec71a5@localhost.talkabouttrucks.com...
the
in
first
and
Have you pulled the valve cover and checked the valve action? How did
you check for misfiring? By disconnecting the spark plug wires one at a
time and seeing what, if any, difference is made?
Didn't you first post that the two middle cylinders were low? What has
changed?
Jarhead
"We have no government armed with power capable of contending with human
passions unbridled by morality and religion...Our Constitution was made
only for a moral and religious people. It is wholly inadequate to the
government of any other."
-John Adams
Old 08-29-2005, 07:01 PM   #3 (permalink)
Calgunz
Guest
Posts: n/a
I pulled the plug wires one at a time. My compression gage was defective
and had to get a new one thats why bad readings first time around. I took
compression second time with all plugs removed. Still not sure but sure
could use some advise.
Old 09-07-2005, 10:01 AM   #4 (permalink)
scott and barb
Guest
Posts: n/a
View scott and barb's Photo Gallery
Open up throttle all the way, ground coil wire 1st.
news:20ab9684eb8fa0162fc07d421a765b37@localhost.talkabouttrucks.com...[color=blue]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
