shift lock question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 08-29-2005, 03:45 PM   #1 (permalink)
Searcher1
Guest
Posts: n/a
View Searcher1's Photo Gallery
shift lock question
When I touch the brake the shift lovk mechanism no longer works, I have to
press the shift unlcok button. ANy ideas on this issue?
Searcher
Old 08-29-2005, 10:12 PM   #2 (permalink)
Searcher1
Guest
Posts: n/a
Re: shift lock question
Never,mind I found a blown fuse? No reason for the fuse blowing that I am
aware of. AGE maybe? Nothing else was going on, it worked fine from one
destination to the next then nothing. No messin with the radio or cig
lighter and the fan motor was off.
Searcher1`
Old 08-30-2005, 01:11 PM   #3 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Adjustment?
However, the brake pedal switch only enables the shift lock button to work.
I don't think you have a problem just bacause you need to depress the brake
pedal before the button works.
"Searcher1" <ACBRN@CS.ver.aol.com> wrote in message
news:2BJQe.5356$__1.2403@trnddc07...[color=blue]
> Searcher
>[/color]
Old 08-30-2005, 02:43 PM   #4 (permalink)
Searcher1
Guest
Posts: n/a
I found the problem, The brake pedal triggers a selenoid that disengages the
shift lock. It is on the same circuit as the brake lights, last week I
removed the hitch and the trailer connector (by cutting the plug off) I
though it was cut clean and I tucked it up. What I neglected to do was to
tape off the end. This trailer connector wire became free and was grouding
out on the exhaust bracket. Tapes it up replaced another fuse and I am good
to go.
Searcher1
BB code is Off
Smilies are Off
[IMG] code is Off
