Transmission problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 08-29-2005, 10:19 PM   #1 (permalink)
JVN
Guest
Posts: n/a
View JVN's Photo Gallery
I have an old 1979 4wd and the clutch had been slipping some and
would engage at the very top of the pedal. I recently started the
engine and could not get it into any gear as if the clutch pedal was
not working. I shut down the engine and basically started the engine
in gear. When the truck moved, I shut it down and started it again in
nuetral. I can now get it into any gear regardless of whether the
clutch is depressed or not, but the truck will not move. No grinding
noises or anything. Any Suggestions before I drop the tranny?
JVN
Old 09-01-2005, 10:40 AM   #2 (permalink)
scott and barb
Guest
Posts: n/a
View scott and barb's Photo Gallery
Re: Transmission problem
check master cylinder and slave cylinder for clutch, get under truck while
someone else depresses the clutch, see if clutch arm moves significantly.
"JVN" <jameselan@yahoo.com> wrote in message
news:Xns96C1E301C52B5jameselanyahoocom@216.196.97.142...[color=blue]
> JVN[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
