Re: AC blinking light
I suspect you need AC service. My guess is the refridgerant is running low.
I'm not sure, but I think your '91 will have R12, which will require you to
visit an AC service shop. It the truck takes R134a, then you can buy a can
of stuff and the necessary guage and fittings for about $20 and perhaps fix
this yourself.
Your system has a high pressure and a low pressure sensor. If either sensor
is triggered by a fault condition, the AC can let you know by blilnking the
light.
"help-slip-franklin" <blacknospam1988@yahoo.com> wrote in message
news:zcYQe.26854$Bc2.5334@trnddc06...[color=blue]
> Hi all,
> I have a 1991 2X4 extended cab with 4 cyl engine. Yesterday the air
> conditioner light (on the button you push) started blinking on and off in
> a
> random manner. It seems like the air is remaining cold and the fan works
> fine on all settings. When it's blinking there does not seem to be any
> change in the rpm's (as if the AC is cutting on and off). Does anyone have
> any ideas?
> Thanks
> H-S-F
>[/color]
