Fuel Leaking Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 09-07-2005, 01:55 PM   #1 (permalink)
Calgunz
Guest
Posts: n/a
View Calgunz's Photo Gallery
I need some advice on what is that Black Canister in the engine compartment
on the passenger side up against the Cab firewall. Mine is leaking fuel
out the bottom and I can't ID what it is or how it works in order to test
it. Anyone got any ideas. Is there another piece. All I see is one fuel
line in the top, One vacuum line in the top and a drain out the botom.
Please help....
Old 09-07-2005, 05:36 PM   #2 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
Re: Fuel Leaking Problem
Calgunz wrote:[color=blue]
> compartment on the passenger side up against the Cab firewall. Mine
> is leaking fuel out the bottom and I can't ID what it is or how it
> works in order to test it. Anyone got any ideas. Is there another
> piece. All I see is one fuel line in the top, One vacuum line in the
> top and a drain out the botom. Please help....[/color]
It's probably the evap canister which is designed to accumulate vapors from
fuel tank and expend them into intake manifold. The canister will accumulate
raw gas if fuel tank is continuously filled too high, commonly called
"topping off". Only fill until pump's automatic fill nozzle kicks off or
only one more click while filling slow, any more will overflow into
canister.
If this is your problem you might be able to stop topping off and the fuel
may evaporate out of canister on it's own. Some canisters are ruined when
this happens, I'd try the first suggestion and see if it heals itself.
HTH, davidj92
Old 09-08-2005, 09:07 PM   #3 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
It's a charcoal filter that scrubs gas that is on its way back to the gas
tank. You can replace this part, it's called a charcoal cannister.
Yours is full of dirt or water. In any case, it can be replaced.
"Calgunz" <jeff.quarles@cox.com> wrote in message
news:606bfeaf0701cf39a2a510cce4038c5b@localhost.talkabouttrucks.com...[color=blue]
> Please help....
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
