Front brake pad longevity 2002 Toyota 4-runner - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 09-23-2005, 08:16 AM   #1 (permalink)
hombrewdude
Guest
Posts: n/a
View hombrewdude's Photo Gallery
I have a 2002 4-runner sport SR5 with towing package.
I thought it was supposed to have upgraded brakes (not sure)
My truck has 48k and the front brakes look good still.
Whats the average life?
Any hints on how to change them?
I loosened the 2 of the caliper bolts, and fluid started leaking..
These are nothing like previous brake work I have done.
Old 09-23-2005, 11:23 AM   #2 (permalink)
Ken Shelton
Guest
Posts: n/a
View Ken Shelton's Photo Gallery
Re: Front brake pad longevity 2002 Toyota 4-runner
hombrewdude wrote:[color=blue]
>[/color]
Yep, never loosen those bolts.
Pad life varies greatly with the driving habits and traffic
conditions of the driver. There is no way to estimate someone
else's pad life.
Don't the pads just slip out after the retainers are removed?
Ken
Old 09-23-2005, 11:30 AM   #3 (permalink)
hombrewdude
Guest
Posts: n/a
I will have to check that..
I sometimes pull a small camper with the truck.
When the brakes heat up they sometimes have some chatter.
Probably warped rotors.
I bought new rotors, so I need to change the pads and the rotors...
I need to find a book!
Old 09-23-2005, 01:09 PM   #4 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
If fluid came out, you didn't loosen the caliper bolts.
"hombrewdude" <hombrewdude@yahoo.com> wrote in message
news:1127481404.376657.324970@o13g2000cwo.googlegroups.com...[color=blue]
>[/color]
Old 09-23-2005, 01:10 PM   #5 (permalink)
Jeff Strickland
Guest
Posts: n/a
news:1127493056.399564.307870@g49g2000cwa.googlegroups.com...[color=blue]
>[/color]
Yes, you do.
Old 09-25-2005, 05:03 PM   #6 (permalink)
Ken Shelton
Guest
Posts: n/a
Jeff Strickland wrote:[color=blue]
>[color=green]
>>[/color]
>[/color]
Loosening the bolts that hold the two halves of the caliper together
will allow fluid to leak out.
Old 09-26-2005, 12:58 PM   #7 (permalink)
hombrewdude
Guest
Posts: n/a
I found that out...
so how do I replace the rotor then?
Old 09-26-2005, 05:57 PM   #8 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
The caliper itself is held on the steering knuckle by two 17mm bolts. Once
the bolts are out, you can slide the caliper off the rotor, and the rotor
pops right off the hub. If you are in to doing basic stuff like this
yourself, grab a Chilton. It's a must have for doing little simple (yet
critical) things like brake work!
Old 09-26-2005, 07:31 PM   #9 (permalink)
hombrewdude
Guest
Posts: n/a
I have done many brakes before on american cars... I never seen one
like this.
Chilton does not make a book for my 2002 truck.. I checked.
Are my brakes different cause it was the towing package?
My rims are 16"
Old 09-26-2005, 11:09 PM   #10 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On 26 Sep 2005 17:31:33 -0700, "hombrewdude" <hombrewdude@yahoo.com>
wrote:
[color=blue]
>like this.
>Chilton does not make a book for my 2002 truck.. I checked.[/color]
You might have to break down and get the Toyota Factory Service
Manual set from the dealer. They are hellaciously expensive when
compared to Chilton or Haynes, but the best and most accurate repair
books I have ever worked with.
You'll get your payback for them the first problem you solve (like
how your front brakes come apart) and you'll get a chunk of it back
again in resale value by passing the books on to the new owner when
you sell the car.
[color=blue]
>My rims are 16"[/color]
Might be, but I don't know. (I have a LandCruiser with the 4-piston
fixed calipers.) They are more than likely different between the 2WD
and 4WD versions of the truck. That might be a case of 'plop them on
the dealer parts counter and see what the parts man says.'
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 09-27-2005, 08:44 AM   #11 (permalink)
hombrewdude
Guest
Posts: n/a
The books are $129 each and there are 2 of them..
I don't mind spending the money on a repair book, since I do everything
myself... But I didn't know how detailed the factory books were...
Old 09-27-2005, 10:00 AM   #12 (permalink)
Jeff Strickland
Guest
Posts: n/a
"Ken Shelton" <shelton@cablespeed.com> wrote in message
news:wradnSWBtIAIg6reRVn-vA@cablespeedwa.com...[color=blue]
> Jeff Strickland wrote:[color=green]
>>[color=darkred]
>>>[/color]
>>[/color]
> Loosening the bolts that hold the two halves of the caliper together will
> allow fluid to leak out.[/color]
Sure, but those aren't the bolts that hold the caliper to the hub assembly,
and hence are not the "caliper bolts".
Old 09-27-2005, 10:01 AM   #13 (permalink)
Jeff Strickland
Guest
Posts: n/a
"Bruce L. Bergman" <blPYTHONbergman@earthlink.invalid> wrote in message
news:qrghj19l4n6e5uoer5k70sqq8eqnh7em2v@4ax.com...[color=blue]
> wrote:
>[color=green]
>>like this.
> Manual set from the dealer.[/color]
.... which is a MUCH better choice, by the way.
Old 09-27-2005, 12:41 PM   #14 (permalink)
Jeff Strickland
Guest
Posts: n/a
news:1127828642.639767.114180@g43g2000cwa.googlegroups.com...[color=blue]
>[/color]
Very.
If you do your own work, you NEED the factory shop manuals. I have it for my
Jeep, and it's WONDERFUL. I can't imagine doing the work without it. The
pictures are, "your framis looks like this," where the Hanyes or Chilton
say, "your framis looks kinda like this," but the framis they are showing
doesn't even begin to approach the part you have in your hand.
If one is inclined to buy a manual, they should buy the factory shop manual
and not even consider Hanyes or Chilton.
Old 09-27-2005, 04:54 PM   #15 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
> everything myself... But I didn't know how detailed the factory
> books were...[/color]
Check eBay if you don't need them in a hurry, they have a wide selection for
various models and are usually at a good price. I've bought 3 new factory
sets there at a lot less than dealer.
HTH, davidj92
BB code is Off
Smilies are Off
[IMG] code is Off
