Re: Truck recommendation
In article <6j2Ze.543$il4.49@trnddc04>,
"Scott Bouffleur" <scotbeth@verizon.net> wrote:
[color=blue]
> Hi:
> Looking for some advice. I have owned several toyotas over the years, and I
> just sold my 99 4-runner to a friend. I'm attempting to locate a mid to
> late 90's or so 2wd pickup. Mostly to use just for around town, occasional
> trips to the dump and towing a small boat short distances. Any years or
> features to avoid?
> TIA,
> Scott in WI[/color]
Go see an engine reconditioning workshop which specialises in Toyotas.
They see all the shortcomings in the most expensive parts of trucks. I
wish I had made a few such calls before buying my 1990 Hilux d/cab 4WD.
Turns out that the Toyota 3L diesel engines (2.8 litre, naturally
aspirated) have 'soft' crank shafts and if oil levels in the barely
adequate sump drop below full for long enough, the #4 bearing will fail.
Guess what? My #4 bearing died. All shops I rang for fix-it quotes said
the same thing... "Don't tell me... It's your #4 bearing!"
Euan
Christchurch
New Zealand
