Re: Check Engine, VSC Off, VSC Trac lights all lit up - 2002 4Runner 3.4
The problem that triggered both the check engine and the VSC OFF/VSC Trac
lights results in trouble codes (DTC) being stored in the ecu. To identify
the source of the problem you need to have the VSC/TRAC trouble code AND the
engine trouble code read. This can be done by a dealer with a hand-held
tester or with any OBDII scan tool. The codes read from the ecu will
identify the trouble area(s) that need to be checked.
"Frank" <Imhere@mypc.dot> wrote in message
news:ONy%e.3418$794.1665@trndny01...[color=blue]
> Recently all 3 lights came on and stayed on. The truck has 38,000 miles.
> I did a search on the net and all I'm finding is it could be the O2
> sensor,
> a loose gas cap (checked and OK), or a cat converter.
> Has anyone had any experience with this situation?
> Thanks
>[/color]
