Whine in the rear, u joint or differential? - Toyota Nation Forum : Toyota Car and Truck Forums
Cressida Forum No one can deny the Cressida has a solid platform. A cult Toyota classic.
post #1 of 7 Old 06-05-2017, 12:30 PM Thread Starter
oblivionnewtonjohn's Avatar
Quoted: 7 Post(s)
(Thread Starter)
My MX73 has developed a whine in the rear, which is amplified by the speed of the car. I do have a small amount of vibration, and hoping it's a $20 u joint, not a $$$ rear end.
What is a good method to test each?
oblivionnewtonjohn is offline
post #2 of 7 Old 06-06-2017, 08:23 AM Thread Starter
Quoted: 7 Post(s)
(Thread Starter)
I noticed that if I am coasting, no matter the speed, the noise is not present. Only when gas is applied and the drive shaft is fully engaged does the noise appear.
My logic is if it were a bearing, the noise would be present as long as the wheels or car is moving. The noise is definitely coming from the rear.
post #3 of 7 Old 06-10-2017, 02:29 AM
RA28 + MX73
Quoted: 8 Post(s)
After 30 years, the centre bearing is almost certainly dead or ready to make that last journey.
Since it is cheap and you will need to replace it soon anyway, replace it now and see if the problem goes away.
Only requires simple hand tools and isn't hard to figure out.
- Stepho (MX73)
stepho is offline
The Following User Says Thank You to stepho For This Useful Post:
oblivionnewtonjohn (06-14-2017)
post #4 of 7 Old 06-15-2017, 06:44 AM Thread Starter
Quoted: 7 Post(s)
(Thread Starter)
- Stepho (MX73)
Thank you for the reply Stepho, are you referring to part #41201B as shown on the parts diagram?
post #5 of 7 Old 06-15-2017, 11:06 AM
RA28 + MX73
Quoted: 8 Post(s)
No.
The centre bearing I am talking about is the rubber mounted bearing that sits halfway along the driveshaft between the gearbox and the diff.
- Stepho
stepho is offline
post #6 of 7 Old 06-15-2017, 11:09 AM Thread Starter
Quoted: 7 Post(s)
(Thread Starter)
No.
- Stepho
Ah ok, so this center bearing: http://www.oreillyauto.com/site/c/de...1418&ppt=C0362
post #7 of 7 Old 06-16-2017, 07:25 PM
RA28 + MX73
Quoted: 8 Post(s)
Yes.
I've replaced that centre bearing on several of my cars and it has made them much better.
Not guaranteed to be the solution of your problem but it's cheap and easy.
- Stepho
stepho is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Cressida Forum
User Tag List
Linear Mode Linear Mode
Back
