Oil light at idle - Toyota Nation Forum : Toyota Car and Truck Forums
Cressida Forum No one can deny the Cressida has a solid platform. A cult Toyota classic.
post #1 of 6 Old 06-13-2017, 11:28 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Oil light at idle
I just bought a 92 Cressida. I drove it home and at Idle the oil light flashed a little, slight rattle and rpm drop. I put it in neutral and park and it stoped. This happened 20 minutes after driving. I called the guy and he said it never happened to him. I had drove a ways to pick it up and had to drive home for work. The light did not come back on and I drove it 180 miles. My question is what are the chances that the pick up screen is clogged? I see in the service records that the oil pan gasket was recently replaced, maybe they used too much sealant? Fingers crossed. I read that the pump hardly fail on these cars? The car is super clean and i love it, but cant do an engine right now.. my plan was to drop the oil pan and inspect. Or try a little thicker oil? I don t know much about these engines.
wrenchit is offline
post #2 of 6 Old 06-13-2017, 11:41 AM
1990 Toyota Corolla Wagon
Thohean's Avatar
Quoted: 28 Post(s)
I had a similar issue on my 1990 Corolla. It turned out to be a bad oil pressure sensor. It's internal seal had failed and so some oil was passing through it and leaking out the back. Not enough to cause a drip on the driveway, but that area was a mess. I couldn't see it very well due to the way the AC compressor and alternator mount to the 4A-FE engine in the corolla.
Thohean is offline
post #3 of 6 Old 06-13-2017, 01:08 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks a million I will check that out.... Thohean
wrenchit is offline
post #4 of 6 Old 06-14-2017, 12:08 PM
Quoted: 2 Post(s)
Also do yourself a favor and buy a cheap oil pressure guage to see what your pressure is before tearing into the motor...
Turboy is offline
post #5 of 6 Old 06-14-2017, 03:08 PM
Kingdom934's Avatar
Quoted: 1207 Post(s)
If the oil pressure sensor was anything like the 5M, they are extremely sensitive.
Best way to do a manual pressure gauge for a piece of mind. Did the engine ever had a headgasket done to it?
'85 Camry DLX 162K
'87 Cressida 78K
'04 Camry XLE V6 108K
'98 Camry LE AE V6 216K
'06 IS250 + sport pkg 131K
'04 Camry SE I4 5SPD 167K
Kingdom934 is offline
post #6 of 6 Old 06-18-2017, 11:59 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks a lot. I have not had the light come back on. But thanks for the info. I do have a oil pressure gauge , i will check it out when i get a chance. I want to limp it along until I can get some cash for a swap.
wrenchit is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Cressida Forum
User Tag List
Linear Mode Linear Mode
Back
