84 Cressida timing belt?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Cressida Forum
Cressida Forum No one can deny the Cressida has a solid platform. A cult Toyota classic.
Old 12-01-2003, 03:23 PM   #1 (permalink)
View 84 Cressida's Photo Gallery
Hi all!!
I am new to the forum as this is my first post and I am glad to have found this site.I just purchased a cherry 84 cressida that has 120K miles on it,it runs strong but leaks oil.
I looked at the timing belt cover and see it was changed at 62,000 miles. Is this due for a new one or do you change them every 80,000 miles.The engine is a SOHC 6 and runs very good.If I wait till the belt fails will there be engine damage??Any info is appreciated and thanks in advance.
84 Cressida is offline   Reply With Quote
Old 12-01-2003, 03:31 PM   #2 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
that should be a 4m-e in that car and if that is the case then you don't have a timing belt you have a timing chain.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 12-01-2003, 03:48 PM   #3 (permalink)
Thanks for the info.
Does the chain need to be changed on a regular basis as with a belt??
Old 12-01-2003, 04:00 PM   #4 (permalink)
SCCA Tech Services
No it doesn't. The only time you replace the timing chain is when it gets a lot of slack in it. You will notice the engine running really sluggish and it will be out of time sometimes. Really I wouldn't worry about it. My celica has a 22R in it and it has a chain and it is on the original chain and it has 137K on it.
Brian Harmer
Old 12-02-2003, 12:29 PM   #5 (permalink)
Just checked the plate inside the engine compartment,it says the engine is a 5M-GE,does this one also have a chain??
Thanks in advance!
Old 12-02-2003, 11:46 PM   #6 (permalink)
SCCA Tech Services
Ok if you have a 5mge then you have a DOHC and not a SOHC and you have a timing belt and not a timing chain. Therefore you shold changed your belt every 60K miles
Brian Harmer
