I don't know how much carryover there is but the MKII supra tsrm says 25k Ohm is the limit, I doubt the 5me was too different. I agree that it's probably not the ignition system, that usually manifests at high rpm where there's more stress on it. plus as mentioned the igniter tends to be an all or nothing item. The coil will usually test very low resistance on the primary winding (low voltage side) and higher on the secondary (high voltage) side... neighborhood of 10k-20k Ohm would be my guess but I could be wrong.
I'm the third to say vacuum leaks, they tend to be most noticeable at low rpms where there isn't much airflow through the engine and the vacuum leak is a larger % difference. I don't think there is a PCV valve but there will be hoses. and lots of them, PCV and otherwise.
I'd watch ebay for a manual for your year...look for the big green and black book, not one on CD or a chiltons/haynes POS.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'87 Chevy S10 pickup 4 cyl, M4, FOR SALE
"You don't get to judge me for how I fix what you break"
It originally gave out on the freeway super bowl eve at 65 now it runs for ten 20 minutes sat night then it stalls as i pull out of the parking sunday afternoon so i really havent driven it on the I 5 since.
I think it s vacuum issue not a pickup , ignition coil, distributor, or plugs or plug wires glad i didnt go for a 150$ ignitor though the plugs and igniton coil (napa doesnt fit as wide as nippon denso ) needed done as i had had the car for 4 years next month.
This is her 198 k 4 year hiccup that i wanna try to solve mano e mano...so where to start? and what tools to survey a leak?
there are any number of hoses that could be at fault. your whole climate control system is vacuum actuated for example. I'd invest in a vacuum gauge, hook it up to a solid vacuum source close to the manifold (T into a line, should have fittings for doing so included) and start pulling hoses one at a time, see if it chances the vacuum or how the engine runs, then plug it back in. when you find one that doesn't change how the engine runs, that's the culprit.
a slightly more volatile method is to get a can of ether and spray (a little at a time) at hoses and junctions. if the engine suddenly revs up, one of the last 10 seconds of hoses was the one. brake clean works too, is less flammable, but not as noticeable.
Oops, my suggestion of PCV valve was wrong, I was thinking of another engine.
Still probably something to do with vacuum though.
The brake booster has a small valve in the line connecting it to the manifold that worth checking.
Does it stall when you press the brake pedal?
Kame's suggestion of spraying is good.
I normally use a cheap and nasty water spray bottle from the $2 shop.
The big thick heavy water drops temporarily block the leak and power comes up again.
don't mess with the idle screw. if it runs, it's good. EGR is inactive at idle anyway.
don't use screws/bolts to plug vacuum lines (or other lines) air can get around the threads, albeit slowly. get actual vacuum blockoffs or loop the hoses back to other vacuum ports. (just don't mix before- and after-throttle plate hoses
