x8 suspension swap??? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Cressida Forum
Cressida Forum No one can deny the Cressida has a solid platform. A cult Toyota classic.
Old 02-25-2009, 03:20 PM   #1 (permalink)
View corod's Photo Gallery
I have an 86 mx7 i just got the whole front x8 suspension, the stuts, brakes, sway bar, steering rak, and x-member, do i have to modify any thing to swap the strut & spindle??? and is ther much to modify if i swap the whole thing can i use the stock 5mge??? can i lose the ABS, and does the steering rak swap to??? thank you for your time and help...
corod is offline   Reply With Quote
Old 02-25-2009, 10:58 PM   #2 (permalink)
Cressida nut
Gameroom cash: $213445
View kamesama980's Photo Gallery
as I've mentioned, swap the WHOLE THING. bolt the strut top mount, cross member 4 bolts, and sway bar/tension rod mounts. no modification needed, use the spindles, steering rack, and everything attached to the x8 cross member.
You will end up with 5 lug hubs and yes you can pull any part of the ABS because your x7 doesn't have ABS.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'87 Chevy S10 pickup 4 cyl, M4, FOR SALE
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 02-25-2009, 11:09 PM   #3 (permalink)
Thank you vary much!! thats cool.. sorry to ask again but does the 5mge still bolt up??
Old 02-27-2009, 10:11 PM   #4 (permalink)
Old 02-28-2009, 01:33 AM   #5 (permalink)
Cressida nut
you'll need newer x8/7mge engine mounts. the mounts are interchangeable between engines but you have to have the right one for the cross member.
Old 02-28-2009, 07:24 PM   #6 (permalink)
thank you...
