Originally Posted by stepho
If pulling the plug lead from #6 made no difference then #6 is not doing any work.
Likely causes:
- bad spark plug lead
- bad spark plug
- bad compression caused by bad rings (blows smake>)
- bad compression caused by bad gasket (oil looks like milkshake or can see bubbles in radiator)
Hopefully it's just a dirty spark plug or the spark plug gap has been squashed closed.
- Stepho
you forgot things like bad injector/injector wiring or burned valve.
blown head gasket would cause rough running from coolant entering the cylinder long before you lose compression enough to be a 'dead' cylinder. I almost hydrolocked #6 with coolant (starting it after sitting) but pulling that wire didn't make any less difference than the others while it was running.
*mod note* removed "coolworld"s counterproductive post
*mod note 2* removed "carcrazy"s counterproductive post
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'87 Chevy S10 pickup 4 cyl, M4, FOR SALE
"You don't get to judge me for how I fix what you break"
Reason: so much crap
