81 cressida will not start when hot - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Cressida Forum
Cressida Forum No one can deny the Cressida has a solid platform. A cult Toyota classic.
Old 05-10-2009, 01:51 PM   #1 (permalink)
View fredriko's Photo Gallery
Cressida starts fine when cold but when hot, it will not start. No sound from the starter, no clicking noise, just dead. If I leave it for 30 minutes, it will start just fine. Please help.
fredriko is offline   Reply With Quote
Old 05-14-2009, 02:35 PM   #2 (permalink)
Saggio's Avatar
View Saggio's Photo Gallery
Sounds like your starter solenoid needs to be replaced.
Saggio is offline   Reply With Quote
Old 09-25-2009, 09:39 PM   #3 (permalink)
View $3@N's Photo Gallery
My 83' has brand new starting gear and still does this, except it turns very slowly and sometimes starts...
Anyone know how to fix this?
$3@N is offline   Reply With Quote
Old 09-28-2009, 11:16 PM   #4 (permalink)
Cressida nut
Gameroom cash: $213445
View kamesama980's Photo Gallery
both of you check voltage drop on all your wiring. put the voltmeter leads on the + terminal and starter + lug. should read 0 while cranking. same for the starter case to the - terminal of the battery while cranking. if there is any voltage you have resistance and in either of those cases you don't want it. then you have to figure out exactly where and fix it.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'87 Chevy S10 pickup 4 cyl, M4, FOR SALE
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 09-29-2009, 04:47 AM   #5 (permalink)
The problem is i dont know exactly where and would not have any idea what i am doing, the car has been rewired so that Acc operates everything that ON does.
Most of the wiring is brand new, this is a real confuser.
I might have to take it to another auto electrician, my local one just seems content to leave it :s
I have already tried 3
Old 09-29-2009, 08:13 AM   #6 (permalink)
RA28 + MX73
View stepho's Photo Gallery
For what its worth, here's the wiring diagram for the MX62.
The EFI diagram has the wiring for the starter.
- Stepho
stepho is offline   Reply With Quote
Old 09-29-2009, 11:50 PM   #7 (permalink)
Cressida nut
the biggest wires are what you're checking but you don't even have to know where the wires are. put one lead on the battery terminal, the other on the starter lug. the electricity will find it's own way.
Old 09-29-2009, 11:58 PM   #8 (permalink)
Thumbs up
If its only happening while it hot should i check it when its hot and cold?
Thanks for all the help, now i just got to make time to try it all out
