torque specs - Toyota Nation Forum : Toyota Car and Truck Forums
Cressida Forum No one can deny the Cressida has a solid platform. A cult Toyota classic.
post #1 of 4 Old 06-22-2010, 02:46 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
torque specs
hey guys
i was wondering wut the torque specs are for the oil pan, intake manifold, valve cover, water pump and cylinder head
oh and for the cylinder head wut should i torque to factory says 58 FT LBS and fourms say 70- 80. torquing to 70 or 80 would that cause the bolt to stretch or screw up the housing
please get back to me asap thanks
k_tieu is offline
post #2 of 4 Old 06-23-2010, 12:12 PM
Cressida nut
kamesama980's Avatar
Quoted: 66 Post(s)
First, you need to specify which engine you're working on. 5MGE and 7MGE are pretty similar but JZ series, 5ME, etc are going o be rather different. I assume you have a 7m since you're worried about head bolt torque
for the 7m (could even use these on the 5m but overtightening hte head isn't really necessary)
-head: using stock bolts (new: torque and loosen 2 or 3 times, used: just torque) 75 ftlbs. Don't worry about stretching them, it's only 17 ftlb higher than stock but it will help keep from blowing the gasket gain. The reason for the higher torque is that they changed several things when they went to the 4v head that made it more prone to overheating and blowing the gasket but kept the torque the same (redesigned the EGR to stay in the head 1/2 way round the cylinder instead of 1/4 like the 5m. 4v head means more surface area to absorb heat. there's also a small coolant passage in the back that wasn't drilled. To top it all off, they went from asbestos head gaskets to graphite (which is a little weaker, I would assume replacement 5M gaskets, even from toyota, are graphite as well) With all that, they used the same head bolt torque, which is why the 7M blows the head gasket so often and why you need to use a higher torque.
-oil pan bolts are in the neighborhood of 10-15ftlb
-intake around 20-25
-valve cover 5-10
-water pump 10mm: 78 inlb, 12mm: 14ftlb
-Russell
"You don't get to judge me for how I fix what you break"
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
kamesama980 is offline
post #3 of 4 Old 06-26-2010, 02:24 AM
CRESSIDA!!!
84Cressida's Avatar
Quoted: 167 Post(s)
-valve cover 5-10
Is the 7M head re-torque mod able to actually stop the BHG gods or just delays down the inevitable? I've always gotten the impression it was the former, but I've never had a 7M so I wouldn't know.
1991 Toyota Camry 40,000 mi
1994 Toyota Pickup 96,000 mi
2005 Chevrolet Silverado 59,000 mi
2006 BMW 330i Sedan 152,000 mi
2007 Toyota Camry Hybrid 110,000 mi
84Cressida is offline
post #4 of 4 Old 06-28-2010, 07:40 PM
Cressida nut
Quoted: 66 Post(s)
in a motor that the gasket is already starting to go, it may buy you some time. when doing a rebuild or applied to a motor with a good gasket already it's as good as any other motor in the same condition/miles.
-Russell
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Cressida Forum
User Tag List
Linear Mode Linear Mode
« Back
