Not expensive 5MGE mods - Toyota Nation Forum : Toyota Car and Truck Forums
Cressida Forum No one can deny the Cressida has a solid platform. A cult Toyota classic.
post #1 of 12 Old 01-13-2012, 10:01 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have stock standard x73 cressy 2.8L Rsi with 156000km on the clock , i don't want to do a engine swap as the engine is in perfect working order just yet...
All i want to do is boost the power about 30 - 40 kw
is there any mods that can help me??
Here is some images
ToyotaDrift is offline
post #2 of 12 Old 01-14-2012, 07:32 PM
RA28 + MX73
Quoted: 4 Post(s)
Sadly, there are no cheap modifications to make to the 5M-GE itself.
Any power gains require opening up the engine and become costly.
It is usually cheaper to upgrade to another engine.
One possibility is to use a larger (2.5 inch), free flow exhaust with low restriction mufflers.
But it will only give maybe 5-10 kW.
I'm interested in knowing how the S.African RS-i differs from my Australian spec GL-i.
Is it possible for you to post a picture of the build plate in the engine bay?
I will then use it to update my website:
http://members.iinet.net.au/~stepho/...cressida1985pr
- Stepho
stepho is offline
post #3 of 12 Old 01-14-2012, 10:16 PM
Quoted: 1847 Post(s)
- Stepho
So, to summarize, the OP should either be happy with the power that he/she has from the 5MGE or sell this car and buy one with higher HP?
zythr is online now
post #4 of 12 Old 01-15-2012, 12:29 AM
RA28 + MX73
Quoted: 4 Post(s)
Or upgrade to a 7M-GTE, 1JZ, 2JZ or 1UZ depending on $$$ and time.
But since he said he wants to keep the engine for awhile, he may just have to accept it as it is.
- Stepho
stepho is offline
post #5 of 12 Old 01-15-2012, 04:16 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Free Flow Exhaust
@Stepho
Interesting , my friend said i should put in a performance exhaust system in .
What about the possibility of a K&N Air filter , could it make a small difference??
One fix that i need is when at the moment of shift to a gear i feel a clonk and u can hear a clocking noise ,
which in turn makes me shift my gears slower , may this problem be in the drive shaft (universals)?
I will post a pic of the built plate later.
post #6 of 12 Old 01-16-2012, 09:52 AM
RA28 + MX73
Quoted: 4 Post(s)
A K&N air filter might add 1-2 kW.
The exhaust would only add 5-10kW at most, assuming the engine is in good condition and you have good quality fuel.
The 5M-GE is already in a high state of tune from the factory (ie gives plenty of hp for its cubic displacement).
So, sadly, you will not find any cheap/easy modifications giving you 30-40kW.
- Stepho
stepho is offline
The Following User Says Thank You to stepho For This Useful Post:
ToyotaDrift (01-16-2012)
post #7 of 12 Old 01-17-2012, 05:59 PM
Cressida nut
kamesama980's Avatar
Quoted: 66 Post(s)
the intake and filter won't make a noticeable difference. exhaust will do more, though 2.5 is a little on the high side. 2.25 with better mufflers would be best. 2.5 with cheaper/quieter mufflers.
I've seen cars with full intake pipe, exhaust, headers, tweaked AFM, and more I can't remember that dyno'd the advertised crank HP but at the wheels...if you assume (only) 15% loss through the automatic it's still only half of what you're asking for and those are all the mods to do short of cams (several hundred USD) or a turbo (sky is the limit)
-Russell
"You don't get to judge me for how I fix what you break"
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
kamesama980 is offline
post #8 of 12 Old 02-29-2012, 01:55 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
How will the 1UZ fit
Im thinking of doing a 1UZ + Turbo swap. There is these guys in S.A that only does 1UZ conversions...
I was thinking how would my cressida w58 gearbox handle this engine?
post #9 of 12 Old 03-01-2012, 04:50 PM
Cressida nut
Quoted: 66 Post(s)
I know there are kits to put a W58 on the UZ. the UZ is in the upper range of the W58's capabilities so if you're hard on it, it WILL break but as long as you aren't regularly doing 5th gear WOT runs or hard launches off every stop sign it'll be OK
-Russell
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
The Following User Says Thank You to kamesama980 For This Useful Post:
ToyotaDrift (03-02-2012)
post #10 of 12 Old 03-02-2012, 05:58 AM
RA28 + MX73
Quoted: 4 Post(s)
The 1UZ W58 adapter kit can be found at the Castlemaine Rod Shop in Australia.
They can ship internationally.
On interesting trick I heard of was to mount the left stock exhaust on the right hand side, pointing upwards and forwards.
The turbo was mounted to this and then a custom exhaust pipe was made which flowed down and under the engine, then to the back of the car.
Same for the other side.
Haven't tried it myself.
- Stepho
stepho is offline
post #11 of 12 Old 05-10-2012, 01:01 AM
DRIFT LIMO
grin's Avatar
Quoted: 0 Post(s)
well here is what i did get every lil bit of power outta my 5m first thing got rid of my ac and power steering and removed all the parts to lightin her up then i removed my egr valve and got a 2.5 exhuast along with a big old filter and homemade intake also advamced my timeing just slightly also got some e3 plugs and ngk wires you can get a msd coil pack but there a lil modding to do i left it as is for now till i can afford the swap i also wight reducted my car as much as possible with out damageing or loseing any parts cut my springs and since i use it for drifting run skinny tires in the back and fattys up front
grin is offline
post #12 of 12 Old 05-10-2012, 02:05 PM
Cressida nut
Quoted: 66 Post(s)
-Russell
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Cressida Forum
User Tag List
Linear Mode Linear Mode
Back
