Light bulb warning light - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Cressida Forum
Cressida Forum No one can deny the Cressida has a solid platform. A cult Toyota classic.
Old 01-29-2013, 01:25 PM   #1 (permalink)
alacran1's Avatar
View alacran1's Photo Gallery
All bulbs are fine, yet the warning light stays on..?
alacran1 is online now   Reply With Quote
Old 01-30-2013, 05:58 AM   #2 (permalink)
Cressida nut
Gameroom cash: $433195
View kamesama980's Photo Gallery
Threre's a little yellow box in the trunk under the carpet that measures amperage flowing through the wires to some (not all) the taillights. Either there's a bulb out that you missed or there's corrosion on a connection somewhere causing resistance which is lowering the amperage.
Another possibility is corrosion/damage on the light diagnostics module itself. Usually caused by water getting in past a bad trunk seal.
-Russell
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 02-03-2013, 02:05 PM   #3 (permalink)
alacran1's Avatar
Where exactly is this little yellow box? Is it on the sides or on the floor?
Old 02-04-2013, 06:41 AM   #4 (permalink)
Cressida nut
In the trunk, under the carpet, I think on the rear right corner somewhere. Pretty sure it's on the side, not the floor.
-Russell
'90 Suzuki VX800
Old 02-07-2013, 03:38 PM   #5 (permalink)
alacran1's Avatar
So is my lamp failure module bad and causing the light in my cluster to turn on even though all my bulbs are fine?
Old 03-10-2013, 11:29 PM   #6 (permalink)
alacran1's Avatar
I opened the module and everything looked fine, any thoughts?
Old 03-11-2013, 04:57 AM   #7 (permalink)
Cressida nut
corrosion on a wire or connector. could be a component in the module is bad electrically (good luck!). could be you missed a light, there are a bunch.
-Russell
'90 Suzuki VX800
Old 03-11-2013, 10:27 PM   #8 (permalink)
View Nark's Photo Gallery
Sometime it could be filament inside the bulb broke but still making contact. That's what happened to mine. Scratched my head for few months on that one. Usually brake bulbs, just look at the bulb, black bulb indicates arcing inside.
Nark is offline   Reply With Quote
