cressida trouble with heat - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Cressida Forum
Cressida Forum No one can deny the Cressida has a solid platform. A cult Toyota classic.
Old 03-12-2005, 01:33 PM   #1 (permalink)
View Mr. Lahey's Photo Gallery
Canada cressida trouble with heat
Hey There! My '85 cressida has trouble blowing air. The heater blower doesn't work on 'low', i've already replaced the switch but made no difference. As well the temp. varies from hot to cold and the fan speed on 'auto' and 'hi' fluctuate. I'm not sure what sort of sensors may be envolved with this system, can anyone help? I'd appreciate any input, thanks, Lahey
Mr. Lahey is offline   Reply With Quote
Old 03-12-2005, 03:01 PM   #2 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
I think you've got a bad blower motor resistor.
The following threads might give you some insight:
http://www.thermactor.com/forum/viewtopic.php?t=5028
http://www.thermactor.com/forum/viewtopic.php?t=629
I suffered from the same issue, just never bothered to fix it.
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 03-13-2005, 01:55 AM   #3 (permalink)
I must have been typing the wrong keywords using search. The threads you found help alot, thank-you!
Old 03-13-2005, 01:32 PM   #4 (permalink)
5M-GE
repinS's Avatar
You're welcome
Hopefully this is the issue. It may be a bit labour-intensive - you might have to take apart the centre console and/or the glovebox area
Old 03-15-2005, 09:45 AM   #5 (permalink)
Yeah, I'm sure the thermosister must be faulty. I figured it must have been something like that. I own two '84 supras so i'm a little familiar with toyota's early climate control systems. However the cressida is new to me and i find it a little more difficult. I've got a 'Chilton's' manual ordered so i should be okay! Any idea what the little box labelled 'power steering' under the radio does?
