GOOD JOB MAN I GOT MINE DOWN TO 2402 LBS, I dont remeber where i seen this but a older nissan or toyota had bored holes into the sides if thier doors,bye the door hinges and the latch , they said it has reduced drag on tthe veichile plus the weight of the metal the took oot..and if you want to get 2000 lbs man you could cut the inner panel under where the old air box was at, maybe 5-6 lbs off the front end shouldnt effect anything...have you removed your dash yet,1 more question in what condition is your weatherstrip arund your f windshield in????
