Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - VVTi controller
Thread: VVTi controller
View Single Post
Old 02-05-2005, 06:34 AM   #5 (permalink)
thespud
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Were you talking about me?
The blacktops seem to work like this, as described on Club4AG -
1. Starting. When you crank the starter there will be VVT operation until the engine fires up, obviously to allow more air into the engine to allow an easier fire up.
2. Coolant temp. There is absolutely NO VVT operation when the coolant tempt is below 50°C except for that brief moment when you operate the starter. Reason obvious, who want to stress a cold engine.
3. Engine rpm. VVT will operate in any rpm between the range of 1500 and 7200 when the inlet manifold pressure is right. The min and max range can be a little out because I was reading from the car tacho. Trust me they are very close.
4. Engine load/inlet manifold pressure. This seems to be the single most important parameter controling the system. The VVT will NOT operate if the inlet manifold has more than about 5 inches of vacuum (can't get the exact reading because everything happen so fast. It's very close.). This is very close to zero vacuum which is atmospheric and that is about the maximum load the map sensor will read to tell the engine in an NA car. As you can figure out the throttle will usually be in the more than 3/4 position for this to happen.
5. VVT will work without the speed sensor.
That is basically what i said in my last post, only in laymans terms.
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
