Brake Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2005, 06:04 PM   #1 (permalink)
View Tigre Tiburon's Photo Gallery
Brake Problems
Recently my 92 Paseo's back brakes started squeaking. I took them apart and replaced wheel cylinders, pads, rotors, ect. I bled all 4 wheels, but now I can't get ANY pedal. The emergency brake works fine.
Any ideas?
Tigre Tiburon is offline   Reply With Quote
Old 10-08-2005, 08:29 PM   #2 (permalink)
View deekay140's Photo Gallery
u got air in the system
deekay140 is offline   Reply With Quote
Old 10-08-2005, 10:03 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
bleed it
Old 10-11-2005, 09:04 AM   #4 (permalink)
lancekilgore's Avatar
View lancekilgore's Photo Gallery
92 had rotors in the rear or are they added. My 93 has drums. when you bleed it start with the back passenger then back drivers side then front passenger then front driver. that way you will ensure to get all the air out.
have you chjecked for leaks to sure it is noot leaking out anywhere?
Lance
lancekilgore is offline   Reply With Quote
Old 10-13-2005, 08:46 PM   #5 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
92 had drums unless he did a swap. I say bleed the brakes and if that doesn't help it, check the seals.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
