Tercel Diesel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2005, 11:15 AM   #1 (permalink)
View SkidPlayte's Photo Gallery
Tercel Diesel
Did they ever make a Teercel Diesel? I was reading about the 39 mpg Tercels and started daydreaming about a french fry oil(BioDiesel) burning Tercel gedtting high MPG #s while smelling like a Mickey-D's on a Friday night. The bio diesel is a pretty interesting concept.
SkidPlayte is offline   Reply With Quote
Old 10-09-2005, 05:30 PM   #2 (permalink)
Nitrous makes me happy...
View Tercel Drifter's Photo Gallery
Yes, they did have diesel tercel's in japan. in fact they had turbo diesel tercels in japan.. Someone on tercel online had used a vw rabbit engine to make there tercel use biofuel
Tercel Drifter is offline   Reply With Quote
Old 10-09-2005, 06:33 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
fed it carrots
Old 01-01-2006, 02:15 PM   #4 (permalink)
View jcm55's Photo Gallery
Yep, in Japan and Europe, you could get a Tercel (aka Corsa) with a 1.5L turbo diesel, called the 1N-T. Apparently it has a reputation for being extremely reliable and gets ~ 50 mpg. I've done a little research, and it looks like this engine has the same mounts and transmission bolt pattern as the 3E-E and 5E-FE, so it should be a bolt-in swap for a 1990-1999 Tercel. Also, it's a mechanically injected engine, so there's no ECU, and no hairy wiring mess to deal with.
There's actually one up on eBay right now for $595:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8025565118
I recently completed a Toyota 2LII-T turbo diesel swap into my '89 XtraCab truck, and am pretty pleased with the results. I'm really seriously considering a Tercel diesel swap now, for more of a daily driver car.
Write-up on the diesel Toyota truck swap if anyone's interested:
http://vpizza.org/~jmeehan/toyotadiesel/
jcm55 is offline   Reply With Quote
Old 01-01-2006, 10:17 PM   #5 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
I've always kicked around the idea of a diesel swap... but since all my mechanical knowledge is based on gasoline engines, I would have a harder time fixing problems with it...
We'll see
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 01-01-2006, 11:34 PM   #6 (permalink)
Diesels are really pretty easy to work on. There's nothing magic inside Just about every problem with a diesel engine boils down to fuel delivery or compression.
Jim Meehan
Oakland, CA
'89 Toyota XtraCab 4x4 truck 2LII-T turbo diesel
'02 VW Golf GLS TDI
Old 01-08-2006, 08:15 PM   #7 (permalink)
The Matrix has you......
View matrix37495's Photo Gallery
this would be a possibility for me. i am taking classes to become a diesel and auto tech. i might look up more about this.
Life is not a journey to the grave with the intention of arriving safely, in a pretty and well preserved body; but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "Wow ---- What a ride!!!"
matrix37495 is offline   Reply With Quote
Old 01-23-2006, 05:26 PM   #8 (permalink)
what would be neccicary(sp?) to swap this engine into a 93 terc? another question i had is about the transmission...would i need a new transmission? or could i use the same one? i ask because the diesel turns slower than the gas engine.
Old 02-03-2006, 03:55 PM   #9 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
I wonder how it runs..does run like the old jetta diesels or is it smooth...how much horsepower and torque...?
TTercel is offline   Reply With Quote
Old 09-17-2006, 11:56 PM   #10 (permalink)
StealthSeo's Avatar
View StealthSeo's Photo Gallery
Thumbs up
i just did the conversions, found the figures on this site:
http://www.cars-directory.net/specs/toyota
If I did my conversions right its about 66 horsepower and about 101 foot Lbs. of torque
Saving the best for last
StealthSeo is offline   Reply With Quote
Old 09-18-2006, 03:00 PM   #11 (permalink)
That Acura Guy
TTercel's Avatar
Holy batman StealthSeo kinda late onthe response....
Nice find though
Old 09-18-2006, 03:27 PM   #12 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Smile
I took a Toyota Diesel for a test drive back in about 1987. It was horrible. The one I tried was used, so maybe it was a mechanical problem, the front end was terribly unstable...
it had no power at all.., The Toyota Dealer was selling it.. well mayb e raw torque, but no horsepower at all. I even took it on the freeway. I am no stranger to diesels, I drove huge honking fuel tankers in the past. We used to hold drag races with them... and my brother was a trucker..
but I would seriously consider finding a diesel and use cooking oil like they do in those science documentaries where people convert to using the used oil from fast food joints. If there is a nice decent diesel, that would be cool. But, when the price of diesel was jacked up to $3.00 a gallon, that made people say no way.. forget diesel..
retiredat44 is online now   Reply With Quote
Old 09-18-2006, 04:38 PM   #13 (permalink)
N/A bites
Tercel GTS's Avatar
I think this one is turbo'd.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 09-18-2006, 04:57 PM   #14 (permalink)
StealthSeo's Avatar
yeah, its was, that has the specs to most models and years and packeges
Old 03-16-2008, 03:24 PM   #15 (permalink)
View reddo_tercel's Photo Gallery
I had one, but we swapped the engine because of all the black smoke that used to come out, it was turbo, but an oil leak forced us to change engines, we put in a 94 tercel engine
reddo_tercel is offline   Reply With Quote
