4efte internals swap??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2005, 07:55 AM   #1 (permalink)
A Brother's Promise
View PaseoJay's Photo Gallery
USA 4efte internals swap???
I have a friend getting rid of some Toyota Starlet parts and one of which is some 4efte cams. Can they really be swapped into the 5efe and do they really make a difference??
PaseoJay is offline   Reply With Quote
Old 10-20-2005, 01:30 PM   #2 (permalink)
Don Riko
View riko666's Photo Gallery
4efte cams no, 5efhe cams, yes, but for the 5efhe cams you'd also need the head, valvetrain and shims to make sure the valve clearances are ok
Enrico - Automotive/Motorsport & Metal fanatic
Car - 1998 Cynos Beta To be turned into a "streetable" track car...
riko666 is offline   Reply With Quote
Old 10-20-2005, 01:57 PM   #3 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
What he said. The 4efte and 5efe cams are exactly the same. You just use different marks on the cam to adjust it.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 10-20-2005, 03:09 PM   #4 (permalink)
Don Riko
on that note, the reason to use 5efhe cams is that they have a slightly longer duration and slightly higher lift (0.5mm)
Old 10-28-2005, 05:51 PM   #5 (permalink)
UTA
Mr. Make It Happen U-T-A!
UTA's Avatar
View UTA's Photo Gallery
Very minimal in truth. Unless you have some sick mods or you take the entire head as described above..you wont really notice those gains. Still a worth wild investment, just make sure you have mods that will help maximize their use immediately.
UTA
http://teamecto.proboards42.com/index.cgi
UTA is offline   Reply With Quote
