What kind of Engine is this?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2005, 09:19 AM   #1 (permalink)
View Nik420's Photo Gallery
Can anyone tell me what kind of engine this is? The guy that shipped it calls it a 4E, and says it is a Paseo engine. My mechanic says it is a Corolla engine and will not fit in my 1991 Tercel, contrary to what the engine seller told me. Here is a link to a photo album.
http://www.villagephotos.com/pubbrow...der_id=1492628
I'm in desparate need of a new engine and was told this would do the trick, but now I am not so sure. I have higher-res photos I can email if someone needs them
Nik420 is offline   Reply With Quote
Old 10-21-2005, 01:28 PM   #2 (permalink)
Toy-Cel
TdotTercel's Avatar
View TdotTercel's Photo Gallery
looks like a 4e to me
It will fit in your car, but with some modifications
its from a JDM toyota starlet....
do a search on here for 4e in the tercel or paseo forums, youll find info on it
1992 Tercel DX
JDM 5EFHE, SRI, ACIS, 4-2-1 headers, 2" exhaust, Magnaflow Hi-Flow CAT
TdotTercel is offline   Reply With Quote
Old 10-21-2005, 01:33 PM   #3 (permalink)
TO Refugee
View ShowCarTercel's Photo Gallery
That looks like a 5efe to me, which is what it is if it's out of a Paseo. Though if he is calling it a 4e, that would be out of one of a couple JDM cars that used the 4efe. But if you are going with 4e, get the 4efte. The "t" is for turbo.
Otherwise, if it's a 5efe. It will work. Talk to TdotTercel about putting a 5efe into a Tercel. He just did it.
Manitoba's First and Only JDM 5efhe Powered Tercel.
It's Running Now!!!
ShowCarTercel is offline   Reply With Quote
Old 10-21-2005, 01:44 PM   #4 (permalink)
Toy-Cel
TdotTercel's Avatar
1992 Tercel DX
Old 10-21-2005, 02:33 PM   #5 (permalink)
Canada Installation tips
I was told it was a 4e. Does anyone know where I could find installation instructions that I could convey to a mechanic? My town is pretty small and has no import specialist shops, like the one I bought the engine from - closest is Montreal - 10 hours away!
I assume it is a 4E from the sticker as well, but I am getting mixed messages. What year of Paseos was this engine used in?
Old 10-21-2005, 02:46 PM   #6 (permalink)
Toy-Cel
TdotTercel's Avatar
it was not in a paseo, its from japan
Looking at the intake, it looks like it may be a 5efhe...
basically the same install as a 5efe...
Did you get a wiring harness or ECU with this?
1992 Tercel DX
Old 10-21-2005, 03:02 PM   #7 (permalink)
I don't know. My mechanic claims it is too big to fit in my car though.
Old 10-21-2005, 03:39 PM   #8 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
It is a 5efe without a doubt. I know because I had a 5efe and swapped the 5efhe in. I should know what each looks like. 4e my ass. That motor is in bad shape too. Tell your mechanic to screw off because if you have a Paseo or a Tercel it will fit with no problems... no major ones anyway.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 10-21-2005, 03:49 PM   #9 (permalink)
so the E4E-P20 label does not indicate it is a 4E??
I'm more confused than before. 5efe or 5efhe?? Does it matter? What is the difference?
I guess I'll be looking for a new mechanic tommorrow
Old 10-21-2005, 03:51 PM   #10 (permalink)
Got a FC3S!
Paseo15psi's Avatar
I just realized that I sounded kind of pissed in the above post. Anyway. Some Cynos did come with a 4e. Not many, but some. It very well could be a 4e. The 4e is 1.3 liter non turbo and is a turd of an engine. Unfortunately it looks EXACTLY like a 5efe until you check the deck height and numbers. It is like a D15 Civic and a B16 Civic as far as comparisons go. Less than 90hp... no improvement over a stock Terc. After taking a closer look at that one pic of the sticker above the crank, I may have to change my mind and say that it appears to be a 4e and NOT A 4EFTE which makes it garbage. Sorry. Good luck.
Old 10-21-2005, 04:37 PM   #11 (permalink)
so does that mean it is not compatible??
I do not know what to do. I had this engine shipped to me from Montreal. Am I wasting my time here?
$580CDN + Tax and shipping - Ripoff??
So does this make a 4E-FE? Sorry about my ignorance, but I need all my terminology right bfore I start contacting mechanics
Old 10-21-2005, 05:40 PM   #12 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
From my understanding all the "E" series engines are built on the same block so everything from your old motor should fit it. The plenum chamber on the intake manifold though does look larger than that of my 5E-FE, so that might be what your mechanic is refering to when he says it won't fit.
If the 4E is a 1.3Litre then I would suspect that you will probably be loosing some performance if you install that engine. At least bottom end torque. I might be wrong, I'm just guessing, since I don't know the spec's on that engine.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 10-21-2005, 05:46 PM   #13 (permalink)
When the stock Tercel engine has a hole in the block the size of my fist, I'd say it is a big improvement. I'm not a performance enhancement guy, I just want a car that works and has good mileage
Old 10-21-2005, 05:58 PM   #14 (permalink)
Donald's Avatar
Ok, I got the picture
Old 10-21-2005, 09:34 PM   #15 (permalink)
View Doekster's Photo Gallery
it looks like a 5EFE to me
Doekster is offline   Reply With Quote
