5efe in 92.... no power ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2005, 01:11 PM   #1 (permalink)
Toy-Cel
TdotTercel's Avatar
View TdotTercel's Photo Gallery
Canada 5efe in 92.... no power ?
We put a first gen 5efe into my 92 tercel, its running, sounds good, but doesnt want to deliver the power....
I can step on the throttle, but it s...l..o....w...l....y speeds up....
what could be bogging it down? it has new plugs and wires
improper plug gap? timing ?? goblins ??
1992 Tercel DX
JDM 5EFHE, SRI, ACIS, 4-2-1 headers, 2" exhaust, Magnaflow Hi-Flow CAT
TdotTercel is offline   Reply With Quote
Old 10-24-2005, 08:31 PM   #2 (permalink)
Nitrous makes me happy...
View Tercel Drifter's Photo Gallery
is the intake clogged at all?
Tercel Drifter is offline   Reply With Quote
Old 10-25-2005, 08:14 AM   #3 (permalink)
Toy-Cel
TdotTercel's Avatar
filter is a bit dirty, but nothing that should cause this kind of lag......
1992 Tercel DX
Old 10-25-2005, 12:01 PM   #4 (permalink)
TO Refugee
View ShowCarTercel's Photo Gallery
My Tercel has no torque. Like I'm flooring it off the light and everyone is beating me, but then I get some RPMs up and then there is some power. Like ACIS power kicking it, though I don't think it works.
Manitoba's First and Only JDM 5efhe Powered Tercel.
It's Running Now!!!
ShowCarTercel is offline   Reply With Quote
Old 10-25-2005, 12:15 PM   #5 (permalink)
WHAT!!!!
View TeRcElIcA's Photo Gallery
I had the same problem for a while after I put my 5EFHE in. But I changed the timing on the 5efhe... which I wasn't soposed to do... sorta screwed up that one. Changed it back ran fine again. Also I know that right when I finished the swap it ran with MAJOR BALLS... that and the Idle was at like 1400 or something like that... really high up there though. I had alot of vacum leaks. But I beat an El Camino with a Corvette engine in it... so i guess it was a good thing.. But as far as your cars lagging, It happen to mine. All it was for me was that stupid ass timing... I dunno though, check your gear oil i guess... always helps to have some.
TeRcElIcA is offline   Reply With Quote
Old 10-25-2005, 01:18 PM   #6 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
Yeah, check your tranny too. I hope that it isn't an auto.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 10-25-2005, 01:23 PM   #7 (permalink)
TO Refugee
I must have the same vacume leak as you had. Mine idles high too, where was your leak? On which line going from where to where?
Sorry Tdot for the thread hijack.
Edit: Paseo15, my Tercel is an auto. Tercelica, Gear oil? Like ATF? Mine is good, blew a line last week and it all leaked out. So it's fresh and new.
It's Running Now!!!
Old 10-25-2005, 01:49 PM   #8 (permalink)
Toy-Cel
TdotTercel's Avatar
s'all good showcar... Were both kind of in the same boat here....
Mine is manual... i'll check and refill the gear oil tonight, could that really effect the power like that?
there are a couple of vaccum lines around the fuel rail im unsure are plugged in correctly...
I have one from my fuel pressure reg. to the intake mani.....
in the pic below (not my car, i just found this pic online) where the sensor plugs in at the bottom of the pic, there are a couple of vaccuum lines going to that, and one behind where the fuel rail is......
Im very unsure that i have these plugged in correctly......
Does anyone have pics of this set-up? or (god forbid) can explain it?
1992 Tercel DX
Old 10-26-2005, 11:15 AM   #9 (permalink)
Toy-Cel
TdotTercel's Avatar
k, i got those vaccuum lines str8ned out, and re-gapped my plugs.....
Say hello to more power
1992 Tercel DX
