5EFE Head Bolt Tightening Question?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2005, 09:18 PM   #1 (permalink)
View reezytercel's Photo Gallery
Unhappy 5EFE Head Bolt Tightening Question??
Hey guys thanks for all the help,
I'm getting ready to install my the head on my 5EFE. The pistons are in and looking good. I found the following picture on the web. I know now that the headbolts are Torque to Yield, so I will be replacing the bolts as well.
My question is simple, I understand that in Step 1: you torque the bolts to 33 ft lbs in the order that is given, 1,2,3,4,5, etc.
I want to know if they should all be hand tight, then to 33 ft lbs, or just insert bolt 1(tighten to 33 ft lbs), insert bolt 2(tighen to 33 ft lbs) ... etc.
I don't want to make this harder then it seems, but then again I don't want to Fu$k up my motor.
Has anyone BTDT before ??
Let me know,
Thanks,
reezytercel
reezytercel is offline   Reply With Quote
Old 10-25-2005, 09:47 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Originally posted by GT_REVVA
Head Bolts
rear
9 3 1 6 10
7 5 2 4 8
front
1st stage=22nm/19ftlb
2nd stage=44nm/32ftlb
Then 90 degrees
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 10-26-2005, 12:21 PM   #3 (permalink)
The Matrix has you......
View matrix37495's Photo Gallery
those specs dont seem high enough for a head....are those right? the haynes manual i have says:
9 3 1 6 8
<< FRONT
7 5 2 4 10
install all bolts finger tight
tighten to 22ft lbs
tighten to 36ft lbs
turn 90 degrees
are these different between motors? mine is for the 3e-e
Life is not a journey to the grave with the intention of arriving safely, in a pretty and well preserved body; but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "Wow ---- What a ride!!!"
matrix37495 is offline   Reply With Quote
Old 10-26-2005, 01:55 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
32, 33 and 36 aren't much difference, but that 1/4 turn at the end is the quencher. I agree, it still seems light. I'll look it up in mitchell for shits and giggles to see what they say.
雄のハヤブサ
