88 Tercel ez engine swap? Help needed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2005, 03:42 PM   #1 (permalink)
View jk8287's Photo Gallery
Have a 88 Tercel ez with a 3e carb engine with 4 speed trans. The motor locked up about 7 months ago. Wondering should i just get rid of it or should i put a different motor in. Friend has a 95 paseo 5 speed trans stage two clutch and just did a starlet swap. How difficult would it be to bolt his motor in and what additional things would i need (fuel pump, axels, harness, etc...). Basically what do i need to do to get her running on fuel injection cause the carb thing sucks? Also A/C still works in mine would the compressor bolt on his?
Thanks
Jon
jk8287 is offline   Reply With Quote
Old 11-02-2005, 04:42 PM   #2 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285880
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
my first toyota was that car
do something off the wall with it, like a 20v silver in it...my 2 cents
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 11-02-2005, 06:27 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
Donald did a 5E swap on his late 80's tercel. Pics are in the gallery.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 11-02-2005, 08:25 PM   #4 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I put a '92 Paseo engine into a '89 2dr coupe. The mechanical part was quite easy but the wiring was a SOB!. If I was to do this again I would get Dr. Tweak or BYP to make me a wiring harnes. It took me 3 months and 1 week to do the wiring, and I will still need to go back in to rewire my headlights, the bright is fine but the low beam seems to not be grounding properly.
Sorry, I digress. Anyway the other problem was getting an inline electric pump that put out enough pressure that didn't cost an arm and a leg, then figuring out where to mount it. I originally put it in the engine compartment but have just relocated it to just behind and above the gas tank.
The pump I am using I got from Advance Auto Parts. The brand is "Master", the model # is
E8445 and I think the price was about $108.00
I also swapped in the Paseo front struts (keeping the Tercel top caps) and brakes (10mm larger diameter rotors). The 13" wheels will not fit over those brakes. I changed to 15" wheels with 195/50/15 tires (closest to original diameter)
I was lucky to find an almost complete donor car ('92 Paseo) in a local salvage yard and was able to get all the engine and dashboard wiring, ECU, vacuum switches and valves from the engine compartment.
The Paseo engine bolted right up to the Tercel transmission. The transmission was the only thing I didn't get off the Paseo (auto). The Paseo engine and transmission will swap straight into your car. The axle shafts I am told are the same. The chassis mount points are the same and the suspension pieces are interchangable.
Are you getting the Tranny too, or just the engine? If not I suggest you find a 5spd. I believe that there are two different transmission ratio sets in the different Paseos (92-95 and 96-98) Somewhere in the posts on this site I believe that there is info on that, you should search that out.
Get the Paseo alternator - (more amps), the power steering pump and hoses.
In the end I think my swap was worth the trouble, and now apart from being my daily driver, I autocross my Ter-seo. Even though the engine swap puts me in a higher class against some realy fast cars, it is great fun.
If you think of anything I didn't cover e-mail me at < donislandman@triad.rr.com >
Good luck
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 11-04-2005, 01:07 PM   #5 (permalink)
UTA
Mr. Make It Happen U-T-A!
UTA's Avatar
View UTA's Photo Gallery
3 months..yipes! Yeah...BYP custom harnesses are the way to go, no worries. I have had 3 so far. As long as its an 87 and up Tercel, you dont usually have too much trouble getting swaps to fit in there. Just the wiring and some fuel mods can get you!
UTA
http://teamecto.proboards42.com/index.cgi
UTA is offline   Reply With Quote
