paseo missing?? sputtering - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2005, 05:34 AM   #1 (permalink)
View aj1978's Photo Gallery
Ok guys need some help here. My paseo starting acting like it was missing. all rpms, all the time, big lack of power. Did a tune up, plugs, wires, cap, rotor, fuel filter, coil. Still doing it. Should I check fuel pressure next, or does anyone have any ideas. There is about 205,000 miles on her and I'd really like to go more. Thanks, for the help
aj1978 is offline   Reply With Quote
Old 11-05-2005, 08:11 AM   #2 (permalink)
lancekilgore's Avatar
View lancekilgore's Photo Gallery
Yes I would check fuel pressure, No check engine light? how about the O2 sensor? when was it changed last. injector cleaner? Try sea foam through the intake. NAPA sells the seafoam, disconect the pcv hose and stick it in the can while running suck up 1/3 of the can and shut the engine off let it set for 15 min then start be whaite smoke for a while but it cleans the cylinders and valves real good. put the rest of the can in the tank to clean the injectors.
Could you have gotten bad gas water in the fuel.
Lance
lancekilgore is offline   Reply With Quote
Old 11-05-2005, 02:05 PM   #3 (permalink)
got it
just got a chance to look at it again, one injector was way off on resistance, replaced it fixed>>>>. nice forum though I'll keep in touch
Old 12-29-2005, 01:17 AM   #4 (permalink)
View idave03's Photo Gallery
can that sea foam stuff damage the engine?
idave03 is offline   Reply With Quote
