radiator pressure build up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2005, 12:21 AM   #1 (permalink)
View tercelite's Photo Gallery
USA radiator pressure build up
can any one tell me why a radiator is building high pressure. my radiator is dripping coolant in the reservoir abnormally high. i change the radiaotor cap, thermostat,hoses and flush the radiator already. i even bleed it to remove air. when i removed the radiator cap during bleeding it, i can see the coolant flowing. what are some possible causes for this pressure build up?
thanks in advance
tercelite is offline   Reply With Quote
Old 11-09-2005, 05:29 AM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Possible head gasket troubles. You can have this tested at a shop with a special dye without removing any parts.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 11-09-2005, 05:41 PM   #3 (permalink)
View tgidavid's Photo Gallery
How high is the pressure? Usually the pressure in the cooling system is around 12-15psi.
When it bubbles over then your most likely culprit is a faulty water pump. When coolant doesn't flow easily, then the excess heat builds up and blows out of your cooling system.
tgidavid is offline   Reply With Quote
Old 11-10-2005, 11:37 PM   #4 (permalink)
thanks tercel gts and tgidavid for quick response. there is new head gasket but still original water pump. i will try changing water pump and will keep you posted on the result.
Old 11-11-2005, 11:04 AM   #5 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
Do you have the original radiator cap? That helps to control the pressure of the system.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 11-17-2005, 11:51 PM   #6 (permalink)
i installed new water pump and new radiator and still the same problem-- coolant coming out of the reservoir. Can the original cap rated 13 psi be replaced by say 15 psi?.
Old 11-17-2005, 11:58 PM   #7 (permalink)
Got a FC3S!
Paseo15psi's Avatar
Yes it can. I have a 1.3 bar TRD cap on mine.
Old 11-18-2005, 01:43 PM   #8 (permalink)
N/A bites
Tercel GTS's Avatar
You really ought to have that dye test done before continuing to spend money on other parts you may not need. Only takes a minute and is cheap.
雄のハヤブサ
Old 11-20-2005, 09:57 PM   #9 (permalink)
i think the problem is solved. The new thermostat i first installed was the cheap one with no air bleed. i put a new one like the original and the engine even runs cooler. thanks a lot guys.
