Anyone know if the stud measurements from an 83 13" 4 lug tercel, and the 83-84 14" Celica factory lug setup might be the same ? If anyone knows, this would save me a trip with the ruler to the junkyard, and I'd greatly appreciate it!
I believe that all four lug toyota wheels have the same bolt pattern, but there is a different offset between front wheel drive and rear wheel drive.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Im looking for a stock Toyota rim that will fit on my 83 Terc's, has 13" now, considering 14", but dont want to go full aftermarket wheels. Would like to keep a bit of the stock look, but want something that looks halfway decent. Like the look of the 83-85 4 lug Supra wheels, but it's rear wheel, and I need front wheel.
I have a 82 HB and I went to a "you pull it" junk yard and pulled some factory wheels off a celica. I bought them for $10 a wheel. I took them home and repainted them. They did fit but the studs were alittle to small. So I bought some lugs that had some angle at the tip.
I would greatly appreciate it if you have pics of the wheels you found. Id like to see what style they are, and how they look
Thanks,
rob
Rob Williams
"Terlet" (Tercel + Starlet)...thought the name sounded like toilet, therefore amusing... - 1983 Tercel 3dr
"Tercules" - 1983 Tercel SR5 4x4
Toyotas have more than one 4 lug pattern. Tercels and corollas seem to have a 4x100mm and celicas others had a larger pattern, I believe 4x110. RWD cars may even have a different pattern and offset.
雄のハヤブサ
The rims that I have on 82 HB are actaully off a 82 celica supra. The rims did fit but you have to get some different lugs becuase the lugnut wholes are bigger than the studs. You can check these out on this website.
