Thanks for the reply. Here is what I know:
The check engine light is not on. The radiator fan does not come on when the car reaches temperate idling. I have verified that the fan does operate, so I know the motor is good. The Toyota garage told me they "thought" that I need a coolant temp sensor. You are correct, there are three switches back in that area. The one that faces the firewall is the coolant temp sensor, which is white on mine. There is a green one like you said, and one other, I cannot remember its color at the moment. But I believe one of them does control the temperature gauge and the other is the coolant temp sending unit. I have the Chiltons manual for this car so I am certain that I have located the coolant temp sensor.
Last week I went to the Toyota dealership and had them quote me a replacement. They came up with about $75.00, which I knew was high. I asked them if there was another place I could pick up the part and the parts guy called the local NAPA himself and gave them the part number I needed. I went to NAPA to pick it up. They gave me a sensor with a maroonish plastic piece, and it did not fit the connector that my white one came off. Today I called the Toyota dealer and asked for the part# myself, and they gave me the following:
89422-20010
Well, if you go to
http://www.motor-parts.net/en/showro...0015&cateid=82
you can see that its nothing like what mine looks like. So I have spent the better part of my day trying to find one that matches mine and that is when I found one in another country at
http://hifine-auto.com/soft.asp?id=809
One common thing I started to find was the part was also using the following part number:
89428-12160 adn 89428-12150. That is what the above link has for its number. When I did a google for those part numbers, I didn't find a consistent picture. One came up looking like the white one I have, another site with the same number had it looking different. So the only place I have visually seen what looks to be like mine is on foreign sites, which doesn't make for easy or quick ordering. I really don't understand why a simple sensor is so hard to replace!
