97 Tercel - Changing Headlight bulb - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 6 Old 12-07-2005, 12:45 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Can anyone give me info. on how to change a headlight bulb on a 97 Tercel? Do I need to unscrew the headlight fixture or can the buld be changed by leaving it in? It looks like it would be very tight by leaving it in. thanks!
renardm is offline
post #2 of 6 Old 12-07-2005, 03:22 PM
idavid76's Avatar
Quoted: 0 Post(s)
Open the hood, twist the plastic locking ring to unlock, pull the bulb out. Put new bulb in twist locking ring to lock. Repeat on other side , close hood and voila! No need to remove headlight assy. maybe a little tight but certainly doable!
"Silly Bitch, Trix Are For Kids"
1995 Toyota Tercel DX 5-SPD
idavid76 is offline
post #3 of 6 Old 12-07-2005, 03:32 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks! Do you also need to slip off that rubber ring that is around the fixture?
renardm is offline
post #4 of 6 Old 12-07-2005, 05:38 PM
Senior TN Member
Donald's Avatar
Quoted: 6 Post(s)
Yes. And don't touch the glass part of the bulb with your bare fingers. If you do, wipe it off with a cotton rag or paper towel. The oils in your skin will cause the bulb to get hot spots where you touch it and shorten the bulb life.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension, brakes, interior.
'87 Corolla, AE82 FX-16, 4A-GZE swap (auto-X'er)
'01 Tundra SR-5, 4WD, V8.
Donald is offline
post #5 of 6 Old 04-19-2008, 11:33 AM
Quoted: 0 Post(s)
There is no plastic locking ring...it's a metal spring clip that hinges on one side and is held in a slot on the other. Unplug the power cable and remove the rubber dust boot. Push the un-hinged end of the spring clip out of the retaining slot and swing the clip out of the way. The lamp will now be loose--pull it straight backward and out.
heliocracy is offline
post #6 of 6 Old 04-21-2008, 12:51 PM
suad618's Avatar
Quoted: 0 Post(s)
Gen5
thats correct since the 95 uses 9003 bulbs which has a plastic locking ring and the 1997 uses h4 bulbs that have a metal hinge that holds it in place
suad618 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Tercel, Paseo, Starlet, and Sera Forum
User Tag List
Linear Mode Linear Mode
Back
