YIKES! TOOOOOO MUCH OIL! :sosad: - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2006, 11:22 AM   #1 (permalink)
View PantherRacer's Photo Gallery
Exclamation YIKES! TOOOOOO MUCH OIL! :sosad:
The story.
Tercel (2e) just went in for an overhaul week b4 last and came in last week with no gas, lil bit of oil. first, put in one quart, car doing good cept for some minor starter probs. Yesterday the problems really start...
Go to esso (following mums in the jeep) to put in oil scince the light is on and the temp guage was pegging cold for a while. put in one bottle, check, still low....2 bottles, still not full. Here I'm thinking I should sit and wait for the oil to run its course and then check. But mums is eager to leave, so I decide to throw in the last bottle for good measure and hope that fulls it.
leave the gas station and the smoke ensues. I think it's just some dirt being cleaned out and burning. further along the car seems like it's got a built in smoke screen maker....Stop to get some glass cut for the side view mirror, check the oil. it's just over the full mark, and kindof dirty. think it'll be fine for a while. drive a lil further & stop again, when it's time to restart the car doesn't want to start...when I finally get it on and try to reverse out of the spot it cuts off on me twice. a little less smoke. drive home, haveto go up a hill to get there. REALLLY slow response, feels like there's no power, just a solid wall of smoke.
get home, check the owners manual, the oil was the correct oil I put in, So it wasn't burning it because it was too light...little later after I finish checking the manual for where the oil drain cap is under the car (wanted to let out a little and also put in clean oil) decided to check the dipstick once again......
THE FRIGGING OIL IS NEARLY HALFWAY UP THE STICK!
damnit 'sall my fault... Wanted to drain the oil today but it is now raining
do you think I blew the piston rings or gasket? or was I just burning up all that extra oil which was probbably whipped into a froth by the crank...plzzzzzz confirm that I was only burning oil.....
Team Panther- Racing
Ready to come an run da place
PantherRacer is offline   Reply With Quote
Old 02-12-2006, 12:12 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
I seriously doubt it hurt the engine.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 02-13-2006, 06:41 PM   #3 (permalink)
yup. drained the excess oil and it's all fine now...
I still want fuel injection though *sigh*
Old 02-13-2006, 07:47 PM   #4 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
[QUOTE=
I still want fuel injection though *sigh*[/QUOTE]
F/I is great, but lots of work or lots of $ to install.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 02-15-2006, 04:47 PM   #5 (permalink)
It'd be better for turbocharching though right?
or how would I go about turbocharching a carb'd 2E
Old 02-15-2006, 05:01 PM   #6 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Check your spark plugs now that you've drained the oil. You might have been drowning them, and its not good to have oil on them.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 02-15-2006, 05:34 PM   #7 (permalink)
Donald's Avatar
Oh yes!
You might want to get with < http://www.back-yard-productions.com/ >
or < http://www.phoenixtuning.com/ >. They con probably answer all your questions and steer you in the right direction.
Old 02-18-2006, 09:52 AM   #8 (permalink)
man I am craving boost right now....need money bad lol
Changed all oil to Mobil1 Synthetic d1live 2nd Generation (2005+) 22 04-15-2007 11:24 AM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
HELP! Ran without oil due to leak Jakelukas Camry & Solara Lounge 4 08-14-2005 12:33 AM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 12:36 PM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 10:48 AM
