What size socket for engine mounts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2006, 02:34 PM   #1 (permalink)
View soccerman58's Photo Gallery
Hi
Guess the title says it all really. Can I get a 24-inch breaker bar in at all of em, or is there one of em in an impossible place?
Phil
soccerman58 is offline   Reply With Quote
Old 02-21-2006, 01:06 AM   #2 (permalink)
View tercelsuperfast's Photo Gallery
i believe they're all 17 mm....
you can get a breaker bar on them all, the rear mount through-bolt may be a 14mm as i remember, also the passenger side mount may be a 14mm, guess they're not all 17mm
The rear mount, mount to chassis bolts are 17mm. The rear mount bracket to trans are 14mm. The rear mount through bolt is 14mm. The passenger side mount to engine block bracket are 14mm. The pass. side through bolt is 14mm. The driver side mount to trans bracket are 14mm, the driver side mount bracket to trans are 14mm, and the driver side mount through bolt is 17mm.....
keep in mind that's off the top of my head and for 95-97 Tercels..........
tercelsuperfast is offline   Reply With Quote
Old 02-21-2006, 02:14 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
91-94 should be same sizes.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Hub nut: what size socket? NickR Tercel, Paseo, Starlet, and Sera Forum 8 12-27-2005 09:00 PM
Socket Size for Gen 3 Valve Cover Nuts 4cyl KILLACAMNY Hardcore Tech and Competition 6 06-01-2004 01:34 AM
Socket size of oil pan drain plug Kooter Camry & Solara Lounge 4 10-17-2003 08:14 PM
