turboing paseo!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2006, 10:46 PM   #1 (permalink)
5efhte paseo on the way!!
View sk8ercasey's Photo Gallery
Talking turboing paseo!!!
just bought turbo, manifold, and wastegate, couple more things to go, was wondering if anyone knows how much boost a stock 5efhe can handle? any thoughts or info would be much appreciated. anyone here from central florida?
and one more ?, anyone know anything about the toyota ct9 turbo?
sk8ercasey is offline   Reply With Quote
Old 02-21-2006, 12:40 PM   #2 (permalink)
A Brother's Promise
View PaseoJay's Photo Gallery
I was going to do the same swap and I believe Paseo15psi (very knowledgable) told me the best to start with would be about 8lbs. But I would ask him directly first before trying it.
PaseoJay is offline   Reply With Quote
Old 02-21-2006, 09:13 PM   #3 (permalink)
View el53's Photo Gallery
i am also going to boost but im using a 5efe. gonna run 5-6 psi max to avoid damage to pistons and exhaust mani. 10psi is safe for a quick burst from what i hear but no for daily use! i have all the 4efte turbo parts btw
el53 is offline   Reply With Quote
Old 02-22-2006, 12:18 PM   #4 (permalink)
View ndestree's Photo Gallery
I agree with el53, if its still going to be used for getting around and your weekend warrior I would go with 5-6psi for the boost and it won't damage anything.
ndestree is offline   Reply With Quote
Old 02-22-2006, 12:44 PM   #5 (permalink)
Gen1
will i have to up the fuel? bigger injectors? if so, what other injectors can i use?
Old 02-22-2006, 07:46 PM   #6 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
N/A Supra MKIII injectors work great. HKS also sells a fuel rail for the 4efte that fits and isn't too expensive. Get a Walbro Supra fuel pump or even a stock Supra fuel pump. If running lower boost just get a new factory Paseo pump, it can flow more than it does now with no problem especially if you upgrade the power wire gauge. Get a FPR of some sort. Do some shopping in the ep82 section of PerfectRun or TaikaKaira. Hey el53, what all 4efte parts do you have? I need to retire my Paseo and do a rebuild. Maybe you have some parts I need?
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 02-23-2006, 11:24 PM   #7 (permalink)
Gen1
will the mkIII injectors plug right in, or will i have to splice them?
Old 02-24-2006, 06:12 AM   #8 (permalink)
Got a FC3S!
Paseo15psi's Avatar
They plug right in, same impedence and everything.
Old 02-27-2006, 09:51 PM   #9 (permalink)
View oklalala's Photo Gallery
what kind of part do you need for 4e-fte??
oklalala is offline   Reply With Quote
Old 02-27-2006, 10:56 PM   #10 (permalink)
Gen1
you have parts? or need parts?
Old 02-28-2006, 11:23 AM   #11 (permalink)
View Gizmo's Photo Gallery
I have a set of 4e-fte pistons connected to 5e-fhe rods FS. PM me interested.
www.torontopaseoclub.com
Gizmo is offline   Reply With Quote
Old 04-18-2006, 04:49 PM   #12 (permalink)
MutantCheese's Avatar
View MutantCheese's Photo Gallery
So what's the 0-60 and 1/4 mile stats with the stock engine and turbo? I was thinking of doing that to my '92.
Shane's 'Seo Gen I 1992
"Oh what a feeling!"
MutantCheese is offline   Reply With Quote
Old 04-21-2006, 02:40 PM   #13 (permalink)
havnt completed it yet, but ill keep ya posted, just orderd injectors yesterday, only a little more to go, im guessing about a month at the most
1992 Paseo JT2EL45F2N0097655 PatPend Vehicles 3 02-26-2007 02:03 PM
Hello, 92 paseo here. MrPaseohead Tercel, Paseo, Starlet, and Sera Forum 15 11-18-2005 04:04 PM
Some help getting a 94 Paseo Pirate1650 Tercel, Paseo, Starlet, and Sera Forum 6 10-21-2005 01:30 PM
PASEO for Tuner Transformation TunerTransforma General Discussion 55 12-23-2004 01:49 PM
Paseo motor? MAMH Tercel, Paseo, Starlet, and Sera Forum 1 02-19-2004 04:38 PM
