4e-fte timing belt tensioner - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2006, 03:24 AM   #1 (permalink)
View kiwiandy's Photo Gallery
Hi from Andrew of New Zealand. I am new to this forum.
I would like to be run through the process of releasing the timing belt tensioner.
I clearly understand all the relative timing position marks and have aligned all correctly in preparation for belt removal.With not having a manual I thought it wise to ask someone who has already replaced a timing belt to give me a run down on the tensioner release to remove existing timing belt.
To get access to workshop manuals in New Zealand is next to impossible as the manual required is in Japanese and translation services are very limited.
Thankyou from Andy.
kiwiandy is offline   Reply With Quote
Old 02-21-2006, 01:57 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
I assume you have the top cover off at least so I'm going as if the bottom cover is still in place;
Pop the access cover off the lower cover near the lower pulley just to it's left. Loosen the bolt you'll find under this cover, do not remove the bolt, just loosen a few turns. Squeeze the belt together at the bottom of the upper pulley, while holding it squeezed snug the bolt back tight. The belt should now be loose enough to slip off the top pulley.
If the lower cover is off the bolt you need to loosen/snug is in the left idler pulley nearest the crankshaft.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 02-21-2006, 02:14 PM   #3 (permalink)
Tercel GTS.
I appreciate your sharing of knowledge and clearly understand your instruction.
With thanks from Andy.
Old 02-21-2006, 04:50 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
No problem, I just had mine off 2 weeks ago so it's fresh in my mind.
雄のハヤブサ
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 02:59 AM
91 replaced Water pump& timing belt 3sfe timings off now??? Toyotasrgreat! 1st & 2nd Generation (1983–1986 & 1987-1991) 3 08-24-2005 12:59 PM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
